I have several small DC motors where if I place an extra magnet to back-up the included magnet, the performance seems to improve significantly.
These motors are 30-40 years old & their performance is degraded. I've been told that it's possible to restore their performance by re-magnetizing the magnets.
How can this be done?
Anindo Ghosh
  • 50,188
  • 103
  • 200
R. Grady
  • 71
I am not an expert here, only having done this once or twice a long time ago, but the "usual" method is to send a very short pulse of high current (e.g. >10A, <1us) through the winding, in order to saturate the magnet completely.
All you need is a large capacitor bank and a switch (plus a frame/shield to hold in in place in case anything decides it wishes to depart in a rapid fashion from the motor) You can work out the voltage needed to charge to by measuring the resistance of the windings (roughly, as it will be a fast rising pulse as opposed to DC you are sending through, but it will give you some idea)
I had a quick Google and found this page which discusses the method. I suggest you try it out on and old motor or magnet first, as it is likely to be a rather empirically judged process. This document looks interesting and useful also.
Oli Glaser
  • 54,990
  • 76
  • 147
    I'm amusing myself picturing an "instant steam engine" on the model railroad. – Anindo Ghosh Jan 19 '13 at 18:13
  • @Anindo - yes, hopefully the engine will remain an electrically operated one :-) On the topic of steam engines, I actually have a little toy steam engine here (a steam roller type, around 30cm long - you use a firelighter as fuel), I recall having much fun with it as a child. I wonder if they ever use (or used) real steam engines for model railroads? – Oli Glaser Jan 20 '13 at 10:49
  • yes, real steam model train engines are a rather expensive but popular segment in g and s scales. – Anindo Ghosh Jan 20 '13 at 21:31
  • Interesting - I just took a look and noticed that Hornby and others make them, according to Wikipedia there are even some diesel/gasoline powered models (interesting thread with pics [here](http://gardenrails.myfreeforum.org/ftopic31-0.php)). – Oli Glaser Jan 20 '13 at 22:16
