-4
What type of diode is best to use when I want to minimize the voltage drop in a 5V DC circuit with about 1500 milliamps in a THT form factor?
Justinas
    You ask as if you've already decided that a diode is the best solution for you. That might not be the case, there might be better solutions. So instead of asking for a diode (which is almost a shopping question, which are off topic) explain what problem you want to solve with that diode. There are solutions that have almost no voltage drop. – Bimpelrekkie Mar 12 '21 at 22:04
Based on the minimal information given I would probably pick a low Vf Schottky diode rated for at least 10V and 3A. But beware the leakage current if it's important to you.
It's hard to recommend a specific part because we have no idea of your mounting preference, physical constraints, cost goals etc.
John D
  • 22,677
  • 39
  • 56
Given your earlier question, look for “or-ing ideal diode”. These will have almost no forward voltage drop. They’re based on MOSFETs instead of diodes.
And here's a previous answer: OR-ing power supplies (diode or mosfet)
hacktastical
  • 49,832
  • 47
  • 138
