Is there a to-scale image available somewhere that shows SOT23, SOT323, SOT523, etc. packages used typically for discrete transistors or diodes, so that someone without access to a PCB layout program could compare them?
All I could find is https://www.centralsemi.com/PDFs/literature/Diodes_SF_English_PDF_Version.pdf which is helpful for comparing the larger packages (D2PAK, DPAK, etc.) but not the smaller ones.
(And https://www.mccsemi.com/pdf/SMDDimensionSelectionGuide.pdf where the displayed images are not accurate in relative size)
For example, here is one from ON Semi covering 6-pin packages
