I am trying to add MIDI OUT capabilities to an audio device - using the same jack. User will select in software if audio or midi is to be outputted.
Currently, the audio jack wiring is as shown (R1 is 1k).
I've thought about switching pin 1 of jack to GND and using pin 4 as active HIGH (to avoid possible sleeve-ring short) - but am unsure if this is best practice as midi specs are active LOW. R2 would need to be low enough to allow 5mA current loop (i.e I can't reuse R1).
Priorities for design:
- Use as few GPIOs as possible
- Low cost/part list
