It is known that a coaxial cable needs a balun to provide an optimal supply of a dipole antenna, because of the common mode current that comes back to the transmitter through the external surface of the shield (as some users clearly explained me in my previous question).
Now, I was asking the same thing about a microstrip line.
  1. Can we apply the same logic applied for the coaxial cable analysis? Can we say that:
  • thanks to skin effect, current normally flows only in the upper part of GND plane.
  • when the microstrip conductors are connected to a dipole, a reverse current flows in the lower part of GND plane
  • to avoid this problem, we use a balun
correct?
I was thinking that this reverse current should be present also in the strip. So why is this line unbalanced? Because these two reverse currents are not equal and opposite?
  1. I've seen that sometimes such a kind of balun is used (tapered balun):
Well, I'd say that even in this case there will be reverse currents in both conductors (in the upper part of the upper strip, and in the lower part of the lower strip). Isn't it a problem because both currents are equal and opposite since the two conducting strips are identical?
Kinka-Byo
  • 3,340
  • 58
  • My (probably naive) observation is that if it's asymmetric, it's unbalanced. – Pete Becker Feb 24 '21 at 13:19
  • @PeteBecker That's a pretty good rule of thumb, honestly. I think you could design a balanced line that's asymmetric but it's way easier to do one that's symmetric. – Hearth Feb 24 '21 at 13:39
I will get back to this
Yes, but the situations are not quite identical, as we shall see.
The thickness of a conducting skin depends upon frequency. Below a certain frequency, current will flow throughout a conductor. The copper in a pcb may be thinner than the shield of a coaxial cable. Hence the frequency at which the conductor essentially becomes two conductors may be higher for microstrip than for coaxial cable.
If the frequency is high enough, and the antenna design (and/or balun) is such that this will occur.
if needed.
Now is the time I want to go back to the original comment you made.
The current that flows back toward the transmitter on the outside of the coaxial does not necessarily reach the transmitter. I tried stressing in previous answer that the flow of electrons, i.e. conduction current, can be "transformed" into "displacement current", which is essentially capacitative coupling. That is, the electrons flowing along a conductor, may "collect" at certain points, raising the voltage at that point, and be capacitatively coupled through "space" to some other point of lower voltage.
If the transmitter feeds the transmission line via a transformer, then the currents, at the point of leaving the transmitter, must be equal, even though further down the transmission line, the currents may be unequal.
There are two senses in which a pair of conductors may be "unbalanced", and we need to distinguish between the two.
A pair of conductors may be "unbalanced" simply by virtue of the fact that we feed different currents into them. That is, they the conductors are unbalanced because they have a common mode signal.
However, a pair of conductors may also be "unbalanced" in the sense that even if we feed them with no common mode current, a common mode current develops in them as one moves away from the transmitter. Such is the case of coaxial cable feeding a dipole antenna.
A pair of conductors will become unbalanced if the electromagnetic fields they generate do not cancel. (That is, they radiate).
So now, back to your question:
Yes, there can be reverse current on the outside of the strip. But you must ask yourself whether the outside surfaces of the microstrip and the ground plane generate electromagnetic fields that cancel each other? It is unlikely while a) the ground plane is wider, and b) the ground plane conducts current from other parts of the circuit.
That is why a microstrip balun needs to "narrow" the ground plane.
Hope that helps your understanding.
Math Keeps Me Busy
  • 18,947
  • 65
  • Thank you for your answer. Will a symmetric stripline have total field cancellation outside the identical strips? – Kinka-Byo Feb 24 '21 at 14:08
    Do you mean symmetric microstrip (as in your diagram with the label "balanced microstrip transmission line") or do you mean symmetric stripline (a center conductor sandwiched between two other conductors)? The EM fields will cancel in "balanced microstrip transmission line" which is fed by a signal with no common mode signal. A _stripline_, however, sandwiched between two planes, will have problems similar to a coax. The inside conductor will not radiate, but the outside conductors may. – Math Keeps Me Busy Feb 24 '21 at 14:18
  • I mean a symmetric microstrip, sorry. So, in this case, will the external field be zero? – Kinka-Byo Feb 24 '21 at 14:20
    Yes, if the applied currents are purely differential, i.e. no common mode current. Note, however, that the easiest way to guarantee that one is applying a purely differential signal, is to feed the transmission line with a transformer. That is how ethernet over Unshielded Twisted Pair works. I have seen portable devices where the antenna is fed directly by a BJT transistor, one monopole connected to the collector, the other to the emitter. The emitter was connected directly to ground and the collector through a resistor to Vcc. This, in general, will not transmit a common-mode free signal. – Math Keeps Me Busy Feb 24 '21 at 14:27
