I'm working on building a silicon free computer and I need a way to store information after power off. Right now, solid core memory seems like the best option. However, the sense line of solid core memory produces a very small pulse of electricity when activated, and I need a way to boost that current enough to flip a relay (~3v,.7A).
TLDR; how can I boost a very small amount of voltage without using an IC or transistor?
Firewolf
  • 67
    I seem to remember vacuum tubes being popular for this. – vir Jan 25 '21 at 17:03
    Germanium transistors are still available in some places I bet. – Andy aka Jan 25 '21 at 17:06
  • Thanks for the tip! Vacuum tubes were before my day, but it looks like the exact thing I was looking for! Now I just have to find one... – Firewolf Jan 25 '21 at 17:08
    Gallium nitride or germanium would meet the definition of silicon-free, but I like the vacuum tube option better. –  Jan 25 '21 at 17:08
  • Bi-stable relays is the answer! – winny Jan 25 '21 at 17:17
  • @Andyaka I think jonk has a stash of Ge semiconductor devices :D – Marcus Müller Jan 25 '21 at 17:19
    Wait, are you looking for *silicon-free* or *transistor-free*? Two pretty different things! – Marcus Müller Jan 25 '21 at 17:20
    BTW, 700mA at 3V is not a relay coil you want to be using unless they are almost free. That's 2W coil dissipation - those must be huge relays, otherwise they'll self-destruct if you ever drive them with DC and not short pulses. You'll be dealing with high currents, and you'll need large decoupling capacitors and/or huge wires to ensure acceptably low voltage drop. For dense designs (i.e. memories), I'd look for something with 100-150mW coils, i.e. ~45mA per coil at 3V, max. But you'll be using that in row/column circuits, so a bit more coil dissipation may be acceptable. – Kuba hasn't forgotten Monica Jan 25 '21 at 17:50
    Redesign the thing to use paper tape. Even more impractical, but +100 style points. – user253751 Jan 25 '21 at 18:02
  • Do you know how much power is available? I wonder if you can use some electromechanical solution, like powering an electromagnet to move another magnet to close a contact. (Which is what a relay does...) – user253751 Jan 25 '21 at 18:03
    _"However, the sense line of solid core memory produces a very small pulse of electricity when activated"_ - exactly how 'small'? – Bruce Abbott Jan 25 '21 at 19:17
  • @BruceAbbott The smaller the core the less energy in the pulse, and it scales approximately with core volume, everything else being relatively similar. Chunky cores can provide quite a kick when they switch magnetization. Small toroidal 50/60Hz mains transformers can drive small reed relays directly - they got enough energy stored in the core for that. They are neither lightweight nor cheap, though. We're basically talking of iron ballast here :) – Kuba hasn't forgotten Monica Jan 25 '21 at 19:56
    Silicon free vacuum tubes are rare - most of tubes have glass shell. Metal case versions exist but they tend to have some glass in electrode wire feedthroughs. Charles Babbage innovated one programmable computer which didn't use electricity, but I do not know is a working version ever built. Even germanium transistors tend to have some silicon based greasy material inside their cases. Stonehenge replica needs a massive amount of stone. –  Jan 25 '21 at 20:09
  • @user287001 Perhaps not silicon free, but semi-conductor free! – DKNguyen Jan 26 '21 at 02:28
    May I ask what the point of all this is? – Circuit fantasist Jan 26 '21 at 02:51
    Better make sure you aren't using any silicone-insulated wires. And lots of transformers have electrical steel as a core, which is an alloy that contains silicon. And of course you can't use the standard vacuum tubes either, as they use a silicon dioxide based glass for their shell! Nuvistors might be fine though. – Hearth Jan 26 '21 at 05:36
  • For vacuum tubes/valves: any guitar oriented music shop will be keen to either sell you some, or point you to their amp service connection, and you'll be able to source ECC82, ECC83, EL86, 6L6 and EL34 valves. They are fun to work with! – ppeterka Jan 26 '21 at 13:45
TL;DR: Any sort of a relay computer with integrated stored program memory (not paper tape) is a small-scale production run no matter how much one wishes it to be just a "one off" experiment. When a circuit, even a simple one, is copied hundreds of times, it needs to be engineered to not only be reliable enough that you won't be tweaking/fixing it constantly, but also so that you won't hate yourself after few hours of assembly. Iteration from smaller to larger "repeat counts" is critical. Prototype everything, and prefer to scale up progressively rather than all at once if you can. Design for manufacturing for a "hobby project" - who'd have thought, right?
I'll interpret silicon-free as semiconductor-free, and focus on that line of pursuit in this answer. Others can surely cover non-silicon semiconductors. I'm also discounting heated vacuum tubes, since they are a royal pain unless you find a rich source of low-power ones used for portable radios. Otherwise you'll be dissipating hundreds of watts in just the row and column amplifiers.
We have two types of memory relevant to such a project: PROM and RAM. First, let's see what storage elements we can use. For PROM, any sort of small switch will do - e.g. dip switches of various forms, or even solid wires plugged into suitable receptacles (think of a solderless breadboard, but with just one contact per signal, instead of a whole column). For RAM, bistable relays work well, although not for your pocket (I'm working on such a computer too, and have settled on relays - many kilograms of them...).
You could also have ROM, i.e. the sort of a memory that can't really be reprogrammed easily after it has been manufactured, but then I'd suggest first emulating it with a semiconductor-based model (e.g. an Arduino coupled to some relays and input voltage dividers), and only committing to permanently soldering-in the program when the whole thing works. That way you can skip the potentially more expensive/cumbersome PROM, assuming that you want a fixed-function machine, or are OK with swapping ROM cards to change programs.
Next, let's see how to couple those storage elements to the data lines (e.g. D0-D7 on some bus). With semiconductors allowed, you'd use a diode matrix - cheap and effective. Without semiconductors, you have to use something else: vacuum tubes (good luck having thousands of those), threshold devices like gas discharge tubes or indicators (neons), or normally open relay contacts.
If you settle on relays for coupling elements, anything that can run some sensibly sized programs (say a couple kilobits of combined RAM and PROM) will consume thousands of relays, and has to be designed very carefully to keep heat dissipation in check: large, dense memories with lots of relays switched on at the same time will self-destruct without good cooling. In fact, you may well find out (as I did) that using non-latching relays for even "dynamic" memories is infeasible, and that to scale things you can only afford a few latching relays switching state at any one time, vs. a whole lot of astable relays keeping their coils energized to maintain their state. With bistable relays, permanence is free (as it may be with cores, except that cores need more support circuitry so it's not so "free" anymore, and you can hardly afford to use them for everything).
As a rule of thumb, small relays that are offered in SMT packages are in the 100mW-200mW coil dissipation range, so it doesn't take that many of them to get the equivalent of a 60W light bulb tightly surrounded by lots of not-very-thermally-conductive densely populated cards just waiting for trouble. 0.5k relays will be a tiny computer with no stored program and just a few registers, or a single-function device like e.g. a square root circuit. It really helps when you don't need to turn on the majority of them at any one time.
How can I boost a very small amount of voltage without using an IC or transistor
E.g. using a transformer. But that way you're boosting voltage only, not power. So the higher voltage is not the entire solution. You then need something else that can convert this low-power high-impedance high voltage signal to a much higher power, lower impedance signal you can use to drive things. Some sort of a device that can conduct relatively large currents but can be triggered by a low power high voltage pulse is needed - various gas discharge tubes can do it (I'm ignoring vacuum tubes here). Depending on how much energy you need, it may turn out that a neon bulb pre-biased close to ignition voltage may do the job. You can then use another neon bulb as a switch, so that the first neon is disconnected from the low impedance nodes until its voltage drops from bias to conduction. Then the other neon switch will connect the now low-impedance path to e.g. a relay coil or a pulse transformer. But such conceptually simple circuits may work well when you have just one on a breadboard, but may prove impractical when you need dozens or hundreds of them to perform reliably, since each will require either individual tweaking or selection of individual components based on parametric testing. Another big mistake is running neons or other discharge tubes exposed to light: after tweaking the circuit, it'll tend not to work as soon as you cover it up inside the enclosure, so it's best to experiment with those well shielded from light, if you wanted to experiment.
If the memory cores are large enough, then you could amplify the sense pulses with saturable inductors, but you'll need a "high frequency" AC source of some sort. A saturable inductor's inductance drops a whole lot when input signal is present, so an AC voltage is normally blocked by the inductor, but not when the core is saturated. I've experimented with a stepper motor driven by a cheap cordless drill as an AC source - in the end, I decided to do something else, but it's not a non-viable idea by any means. It just didn't fit into my design criteria.
There's a whole other design criterion that in hindsight is obvious enough, but can catch you unaware: parameter spread, both intrinsic (device specs) and extrinsic (operating environment). Things get real annoying when the whole design has only a narrow voltage or temperature range where it'll work, never mind a narrow range of some critical parameter of a group of components. This works great on paper but just doesn't scale at all. You can deal with tweaking a hundred things if you are dedicated enough, but tweaking a thousand things that then get inserted into a chassis and don't work anymore because they are 40C warmer than they were on the bench can be a bit of a setback. So try to stay clear from any circuits that require tight tolerances on anything. Ideally, you'd want the thing to not care about +/-25% operating voltage changes, and 50-80C in-system operating temperature range. Squeezing thousands of electromechanical components into a reasonably sized enclosure will have some components (e.g. those in the geometric middle of it all) running quite a bit hotter than those on the cards near the enclosure surface.
And you don't get any voltage regulation without semiconductors or vacuum tubes unless you use a saturable transformer as a regulator, but even then it's a risky road to take. Any optimistic decisions made are very hard to rework when even a minor component change (e.g. a different 2-terminal passive part in some coupling or snubber network) implies reworking hundreds or thousands of parts, with some potential for collateral damage along the way.
And also: fuse sub-modules individually on the supply lines, and if the busses aren't inherently conflict-proof (i.e. "open collector" etc.) then fuse each contact driving the such a bus line. A push-pull bus line with just one stuck contact will happily destroy all the other contacts that attempt to drive some other state onto it, in rather short order. Fast, non-resettable fuses are critical for such bus drivers. Push-pull signals can be good in reducing complexity sometimes, but I abandoned them early enough not to suffer too badly. It was a clever trick that proved not to be too clever, although I'm sure someone cleverer could get it to work well at scale - I just didn't have the time.
Plenty of relay computers do use semiconductor memory and don't have a big problem with bus conflicts, since the memory subsystem couples to the bus at one point only. But if you use multiple cards with switches/latching relays/cores, kilobits of memory will take dozens of large cards, each with bus drivers. Many failure modes will result in bus conflicts - say you got a stuck contact in address decoder, and thus bus conflicts must be either inherently safe, or at least well protected from if they can't be made safe (thus fuses).
  • Thanks for the explanation. By silicon free, I meant silicon and semi-conductor free. I understand, there is nothing practical about this project, i'm just in it for the challenge. This post helps a lot though, thanks for sharing! – Firewolf Jan 25 '21 at 20:21
  • @Firewolf Good luck on your endeavor. I think, though, that practicality is a factor even if the project as a whole is "crazy". The craziness of the project doesn't mean you should go crazy implementing it :) Extremely impractical systems can be designed and manufactured in most practical ways! – Kuba hasn't forgotten Monica Jan 26 '21 at 19:24
Reed relays use the lowest of all electromechanical relays and are reasonable fast. There may be contact bounce so metastable conditions must be mitigated with synchronous operations and small storage caps. This naturally raises the transient EMI when thousands are operated in parallel. Debugging failed components will be troublesome.
    But the glass in reed relays (and for that matter vacuum tubes/valves) technically contains silicon, so they are not silicon-free. (Yes, I'm probably taking the OP's title too literally, LOL.) – John D Jan 25 '21 at 18:38
  • I've found surplus reeds that close in 100us and open in under 1ms (that's the bounce time). Reeds are awesome with their fast propagation for combinatorial logic, as long as you can cool them to avoid meltdown. Thermal management when you got closely spaced cards full of relays is a real pain. The two things I found the hardest when putting together a relay computer were EMC (I want to be a good neighbor) and power management/inherently low power design. Lots of different snubbers that go across coils and across some contacts (I don't use diodes). – Kuba hasn't forgotten Monica Jan 25 '21 at 19:01
  • To depend on 0.1ms/1ms reeds in a combinatorial design, they all need to be opened at the same time. That way with e.g. 10 layers of relays you have 1ms propagation on rising edge, and then they all reset (turn off) in parallel. All in all, relays are not "simple" components at all when you're close to the performance limits both at the device level and at the system level. More insightful people would call it a real pain the behind, especially when a hobby project becomes a 2nd job...but I'll finish it, I'm too deep into it now, and things begrudgingly start to work if I pester them enough :) – Kuba hasn't forgotten Monica Jan 25 '21 at 19:07
I'm slightly surprised that you've heard of core memory but not of vacuum tubes; did you not come across ENIAC in your research?
ENIAC pre-dates the invention of core memory. But valve amplifiers are quite sensitive; enough to pick up the response pulse from core memory. Don't forget that core memory reads are destructive, so you have to cache the read and write it back out again afterwards.
Most of the valves circulating are "new old stock", but there are some new-manufacture ones for the audiophile industry. Prices seem to be in the $10-$20 range.
pjc50
  • 46,540
  • 64
  • 126
Core with tubes works (Ceramic if you really want Si free), but come on, that is boring....
For ROM, print your program onto laser printer acetate, roll into a drum and use CDS photo resistors to do the readout, ultimate would be 35 or 70mm cine film spliced into a loop.
For RAM, there are so many, many amusing possibilities.
A drum memory made of thin PCB covered in high value MLCCs, reed relay refresh logic for the win, the arcing and clattering would be glorious if not very reliable.
Or how about this one, a marble machine, serial in, serial out memory, steel or glass balls with a couple of solenoids to handle the write and read out. Given that a serial input ALU is probably the canny way to handle the adder, it is possibly marginally less nuts then it sounds, and you could literally have a stack limited by the height of your storage tube.
Use steel and glass and put an illuminated glass screen behind your register bank and you get blinkenlights. A 16 bit ALU is actually quite practical here, possibly even with a little 1 bit marble memory for the carry flag in the serial addition. Clock speed would be limited by gravity....
I am seeing a bank of vertical tubes each containing 16 mixed balls, with a 'select register' instruction that moves the read/write/refresh mechanism to the appropriate location, then an ALU operation that causes the balls in the register and the accumulator tubes to both drop in sequence into the serial adder and new balls to drop into either refresh or write the result.
Sounds like it would be a cool Covid project, if I did not already have three of those on the go.
Dan Mills
  • 17,266
  • 38
