Below is LTspice simulation in which this error occurs.
The error is Unknown subcircuit called inc xu1 n001 n003 op opamp
How do I fix this error?
LTspice simulation
Voltage Spike
  • 75,799
  • 80
  • 208
  • With no partnumber on the schematic shown, are you sure you applied a model to the opamp? If you used one of the Generic/Universal models, you may have to specify the actual opamp characteristics, or supply a component spice model before the simulation can run – Luke Gary Jan 21 '21 at 20:06
You have no model for the opamp, every component needs a model:
add the line .lib opamp.sub for further reading on adding models see these links
https://www.analog.com/en/technical-articles/ltspice-using-an-intrinsic-symbol-for-a-third-party-model.html
How do I import a spice model into LT spice?
Voltage Spike
  • 75,799
  • 80
  • 208
