I'm designing an Ring Oscillator based PUF as part of my Masters Degree Research.
Enviroment:
Vivado 17.4
ZYBO (XC7Z010).
My design plan is as follow:
I have created three files , datapath, controller and a top module. In the Top module both of the datapath and controller are instantiated.
The datapath is the core Ring Oscillator PUF with a counter which counts its frequency.
The Controller is basically an Moore FSM. Which enables the RO for 0.5ms using a 100MHz Clock. So with a period of 10ns , it keeps incrementing a 16 bit counter and see if the it reached 50,000. If it is , it set enable = 0 meaning that 0.5ms has passed.
datapath.v
`timescale 1ns / 1ps
Whenever enable signal is set to logic 1, The ring oscilator keeps generating a square wave ,
which is fed into a 32-bit counter ,  on every negeative edge of the pulse (clock) the counter
gets incremented by 1.
module datapath(
    input enable, reset,
    output  [31:0] counter
// Intermediate Connections
wire w1,w2,w3;
// Output of Ring Oscillator
wire clk;
// 32-bit register to hold value for the counter
reg [31:0] count = 0;
and #2(w1, enable, clk);
not #1(w2,w1);
not #1(w3, w2);
not #1(clk, w3);
always@(negedge clk)
 begin
    if (enable)
        count <= count + 1;
    if (reset)
        count <= 0;
  end
  assign counter = count;
endmodule
controller.v
For a 100MHz clock on the FPGA, The counter will have exactly the value 50,000 in the counter.
Period of each clock cycle will be 10ns , so 50,000 X 10 = 500,000 ns =  0.5ms
This controller enable the RO enable for 0.5ms and see how much it the value of counter is after 0.5ms, aka RO frequecny.
module controller(
    input clk,
    output reg reset = 1'b0, enable = 1'b0
parameter START=0, RUN=1, STOP=2;
reg [1:0] state;
reg cmp = 0;
reg [15:0] counter = 0;
always @(posedge  clk)
begin
    case (state)
    START:  begin
                enable <= 1;
                state <= RUN;
            end
     RUN:   begin
                if (cmp)
                    state <= STOP;
                else
                    state <= RUN;
             end
    STOP:
            begin
                enable <= 0;
             end
    default:
             state <= START;
    endcase;
end
begin
    counter <= counter+1;
    if (counter == 50000)
        begin
            counter <= 0;
            cmp <= 1;
        end
     if (reset)
            counter <= 0;
end
endmodule
top.v
Datapath:
input: enable, reset,
output:  [31:0] counter
Controller:
input :  clk,
output: reset, enable
module top( input clk_f, reset_f ,   output [31:0] counter);
wire enable, reset;
datapath D(enable, reset, counter);
controller C(clk_f, reset, enable);
endmodule
Test Bench:
module testbench();
// inputs
reg clk;
reg reset;
// Output
wire [31:0] counter;
top uut(clk,reset,counter);
initial begin
    reset = 0;
    clk=0;
    forever #5 clk=~clk;
end
initial
begin
#100 $finish;
end;
endmodule
The results with the test bench  enter image description here
Running the simulation for 0.5ms The results seems correct and indicating the design works as expected.
To see the results on the hardware. I have created IP block design having the top  (ON PL) connected to AXI GPIO with 32 bit channel.  Then then AXI connects to AXI Interconnect and finally ZYNQ processing system (PS).
The block design is as follow:
In the SDK to read the AXI GPIO :
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xgpio.h"
#include "xparameters.h"
#include "sleep.h"
int main()
    init_platform();
    XGpio data_ch;
    int data;
    XGpio_Initialize(&data_ch,XPAR_AXI_GPIO_0_DEVICE_ID);
    XGpio_SetDataDirection(&data_ch, 1,1);
    while(1) {
        data = XGpio_DiscreteRead(&data_ch,1);
        printf("Counter (32-bit): %d \r\n", data);
        usleep(1000000);
    cleanup_platform();
    return 0;
And here I'm continuously receiving 1.  Which is not the case. For an RO based PUF the output is expected as 180K-200K.
Can anybody point out the flaw the in the design?
The full Vivado Project is here. 1RO_datapath_controller_design_sdk.zip
UPDATE:
For quick debugging I commented the always block in the datapath and set the count REG 999.
After generating the bitstream again, and reprogramming the FPGA from the SDK and running , I get 999.
So this confirms the datapath is OK, problem is the controller (FSM). ?
But how come it works as expected on the workbench?  ?
Khaalidi
  • 58
  • Look at the **gate-level** schematics of the final synthesized design to see how the ring oscillator was synthesized. Try creating just a ring oscillator without all of the other baggage, make sure you can successfully build the RO before adding the other parts of the design. – Elliot Alderson Jan 21 '21 at 18:07
    Make sure you have optimizations turned off. Check all logs to see if any logic is being simpliifed. The synthesizer could be optimizing logic you want out. – Voltage Spike Jan 21 '21 at 18:26
  • @ElliotAlderson Thanks for the comment. Okay I'll take a look at the synthetized design only for the RO. But I wouldn't program that to the FPGA as an RO is a high speed element and it could damage the FPGA. For the same reason the Controller was designed to keep the RO in control and enable it only for a short time. I'll update you after I take a deep analysis. – Khaalidi Jan 21 '21 at 19:42
  • Damage the FPGA? Where did you get that information? If you want to slow down the RO you can always add more inverter stages. – Elliot Alderson Jan 21 '21 at 19:45
  • @ElliotAlderson Yes , An RO makes combinational loops. For example if we instantiate three not gates chained together in a ring, and disable or ignore the synthesizers warnings about such a structure, you can make something which is very bad for an FPGA. An RO can be much more faster than FPGAs maximum frequency, it is possible to heat the silicon considerably. Without sufficient cooling this can cause physical damage. – Khaalidi Jan 21 '21 at 19:56
  • @VoltageSpike Thanks for the advice. I will see the logs and confirm whether the synthesizer is optimizing the design. – Khaalidi Jan 21 '21 at 19:57
    @Khaalidi I understand quite well how a ring oscillator is created and how it behaves. They are commonly used as test structures for wafer-level diagnostics. But where did you hear that a ring oscillator could **damage** an FPGA? The heat generated by a small RO is tiny. – Elliot Alderson Jan 21 '21 at 21:30
  • @ElliotAlderson I read it here while searching about combinational loops. https://electronics.stackexchange.com/questions/293915/vhdl-that-can-damage-fpga – Khaalidi Jan 21 '21 at 22:26
    @Khaalidi Sorry, I don't think that is a reliable source. If Xilinx or Altera said it I would believe it. – Elliot Alderson Jan 21 '21 at 23:45
  • @Khaalidi - that reference refers to having many many ROs within the device. A single RO should be fine – Martin Thompson Jan 22 '21 at 15:08
  • @MartinThompson Thanks for the clarification Martin! Can you take a look at my design and see if any you can find any design flaw. The design works as expected with the testbench, but not on the real FPGA. – Khaalidi Jan 22 '21 at 18:47
After spending hours to find the flaw in my design, I finally found the flaw. The lecture of Michael B. Taylor from University of California San Diego of the course CSE 141L: Introduction to Computer Architecture Lab was a lead to find the flaw.
In one of the lecture he advises to always use posedge for nonblocking assignments.
In datapath.v I made only this small change.
always@(posedge clk)
 begin
    if (enable)
        count <= count + 1;
    if (reset)
        count <= 0;
  end
And now I can get the RO output instead of 1s.
But I still doubt how come this even worked with the testbench?
Khaalidi
  • 58
