I'm in the middle of a design and I need a capacitor of:
  • 10µF
  • Rated at 10V
  • Has to handle a ripple current of 250mA RMS, at 400kHz
Most electrolytic capacitor data sheets give a maximum RMS value for the current. However, I would rather use a ceramic capacitor for this application.
I'm about to use a X7R from Kemet, package 0805, the C0805C106K8RACTU. In its datasheet I've found:
  • The data sheet indicates a Dissipation Factor of 10%, measured at 1kHz.
  • I can now estimate the ESR at 400kHz with the usual formula $$ ESR = {{DF}\over{100}} \cdot {{1}\over{2\pi f C}} = 0.004\Omega$$
  • Dissipated power is then $$W = ESR \cdot RMSi^2 = 0.25mW$$
To check if I'm within range, I should either:
  • Find in the data sheet some indication of the maximum dissipated power by the device. But this information is not present.
  • The data sheet does provide the maximum working temperature: 125ºC. To use this information I also need to know the thermal resistivity in ºC/W, but this information is not present.
I would go to another manufacturer, but I have not seen yet any capacitor data sheet providing this information.
How do I know what is the RMS limit for the current in the case of a ceramic capacitor?
EDIT:
  • I understand that my example is quite in the safe zone. However, my question is more general: Where does the safe zone end, according to the datasheet?
  • I've seen this similar question, but there is no definite answer. One comment propose to check the data sheet (and this exactly the sense of my question). One answer says to compare the dissipated power with a Pmax value. Again, in ceramic capacitors, I can't find this kind of information.
jmgonet
  • 983
    At under 1 mW and bigger than 0402 I wouldn't bother. –  Jan 13 '21 at 19:12
  • I think this post covers your question. https://electronics.stackexchange.com/questions/232232/how-to-calculate-capacitors-power-rating – Phelper Jan 13 '21 at 19:15
  • @BrianDrummond I understand that I'm quite probably in the safe zone but my question is more general: where the safe zone ends, according to the datasheet? – jmgonet Jan 13 '21 at 19:21
  • @Phelper Yes, I've seen this question, but there is no definite answer. The better answer suggests to «check that this value is below Pmax», but I can't seem to find a Pmax in any ceramic capacitor data sheet. – jmgonet Jan 13 '21 at 19:23
  • thermal resistance is similar across components of the same package size. for example a TIP120 and an LM317 have about the same junction to case resistance, despite being quite different internally. – dandavis Jan 13 '21 at 19:32
  • For that cap the DF is at 1kHz. That may be meaningful for your application. But always check, because DF is often given at 100 Hz, and the ESR at high frequencies will be MUCH lower than the DF from 100 Hz suggests for ceramic caps. The ESR you calculate from 100 Hz DF in a ceramic cap may be off by 2 or 3 orders of magnitude at 1 MHz. – user57037 Jan 13 '21 at 20:00
  • One other observation which is a bit roundabout. The DF is measured, according to the datasheet, by applying a 1kHz, either a 0.5 or 1.0Vrms sine wave. Presumably, it would be safe to use the cap in conditions that produce the same or less current as the test conditions. So you can calculate the current under those conditions using your ESR and capacitance and then compare with the ripple current in your application. As long as your RMS ripple current is less than theirs you should be OK. (Hopefully). – user57037 Jan 13 '21 at 20:07
  • For ceramic capacitors this dispassion factor may not be correct way to specify the power dissipation. Previously I have checked with others about similar calculation, but I don't see thermal resistance data from datasheet. Only way to make sure ripple current handling capacity is to see ripple current curves at different frequencies for specific temperature rise and make sure it is with in limit. – user19579 Jan 14 '21 at 02:02
  • https://electronics.stackexchange.com/questions/358536/unrealistic-esr-calculated-from-df – user57037 Jan 14 '21 at 04:38
    As an aside, be aware of dc voltage bias affecting the capacitance. If you’re operating at 5V, the 10V rated device may not be giving you the capacitance you expect. You might need a 25 or 50V rated part. – Kartman Jan 14 '21 at 12:16
The allowed RMS current appears to be rarely mentioned in ceramic capacitor datasheets. Have a look around for additional information provided by the manufacturer on their website. KEMET for example provides a lot of information in their design tool KSIM. They also provide the most important data in additional specsheets, e.g. C0805C106K8RACTU.
You can directly reference the max RMS current characteristic:
Max Current and Voltage for C0805C106K8RACTU
Other manufacturers like TDK don't directly provide the current curve, but the ESR and Ripple Temperature Rise curves. They also state in their specification, that the temperature rise at the capacitor surface should be below 20°C. Example plots:
ESR of C2012X7R1A106K125AC Ripple Temperature Rise Characteristics of C2012X7R1A106K125AC
Source:TDK C2012X7R1A106K125AC Characterization Sheet
So using the ESR graph and the Temperature Rise graph at the same frequency, you can easily calculate the maximum power dissipation: $$P_{max} = ESR \times I_{RMS}(20°C)^2$$ And with the ESR at your frequency of operation you can then calculate the maximum RMS current.
Popular manufacturers like Murata, Samsung, AVX etc. all provide this kind of information. But the datasheet that is provided on the websites of the distributors is often more like a catalog than actual data. Make sure you check the manufacturers website for this kind of information for the specific capacitor of interest.
Lars Hankeln
  • 2,513
  • The KSIM tool gives helpful information. In particular, I can see that the ESR at 400kHz is indeed 4mΩ. However, it doesn't provide either Pmax or thermal resistivity, so I have no means of checking if my power dissipation is within range. – jmgonet Jan 14 '21 at 06:17
    Just added some more information to clarify. – Lars Hankeln Jan 14 '21 at 06:22
    Oh, yes. Now, if I visit the KSIM but with my eyes open, I can see the drop down selector where I can select the data to display. Thanks! – jmgonet Jan 14 '21 at 06:35
  • This really answers the question. Great job. – user57037 Jan 17 '21 at 07:09
For multilayer capacitors, the thermal conductivity is affected by the number of plates, which are more highly thermally conductive. Therefore, a high-value capacitor will have a higher thermal conductivity than a low-value capacitor in the same size. There is a good discussion of this in https://www.newark.com/pdfs/techarticles/kemet/Ripple-Current-Capabilities-Technical-Update.pdf .
John Birckhead
  • 10,524
