From my understanding,
The diffusion layer at a p-n junction is an equilibrium of two opposing forces on charge carriers due to 2 forces - Concentration Gradient and Electric Field caused by Bias and inturn by diffusion caused by Concentration. In steady-state (with or without bias) forces are perfectly balanced at an attained equilibrium (which is dynamic and changes with bias). Now the forces are all balanced, all that causes this dynamic resistance effect is the change in the size of the depletion layer thus resistance, not these forces since they've been balanced now.
Hopefully, that's the right picture of it. I'm trying to see how the depletion layer between Collector and Base changes with \$v_i\$ at Base (Common Emitter connection). I can see that depletion later EB is decided solely by the biasing 0 to \$v_i\$. What I cant explain is how this affects the depletion later BC.
What I'm trying to do is roughly get what happens to the resistance(\$\frac VI\$ rather than \$\frac {dV}{dI} \$) between Base and Collector, use \$I_e \approx I_c\$ and ohm's law to get graph between \$v_i\$ and \$v_o = v_C\$
Skip if needed: I searched up, all explanations have a "Current simply accelerates into Collector" which I clearly get from \$I_e \approx I_c\$ but don't get how that leads any relation between base current and collector current obtained or the output characteristics. I found this book in an internet archive by Millman & Halkias, read through chapter 5 where it reaches Output characteristics, didn't get it yet. Read other related questions like Why is Ib proporional to Ic in a bipolar transistor? , still don't get a qualititive picture other than the "Current is attracted by Forces" explaination or a "it gets into Semiconductor Physics and complex Math". The former explaination does not appeal to me because the forces are now balanced right? Isn't resistance by depletion layer causing this and not the forces? So what happens to this depletion layer?
Or more appropriately,
The Question: Can someone give a qualitative explanation of Output characteristics of a BJT using depletion layers instead of the regular "Current is attracted by Forces" one?
Thank you
