CONTEXT : I'm working on a project consisting of making an underwater robot "fish" for an aquarium . and it is mandatory to get at least 8 hours of autonomy. I'm responsible of the electrical part of the project and during all of my bachelor degree i've never got any lecture on batteries and i have no idea on how to get what is required. But i managed to do some research and try to figure it out :
1- First , I took the power consumption of all the potential componants necessary for the project (motors & pumps, Usound captors, ucontroller and a set of RF reciever and transmitters) from the specs and datasheets available.
2- I Got a battery of a 1200 mAh capacity. The battery is originally used for quadrocopters, i figured it would be good for the project since it's relatively the same thing (a software and motors).
3- Thanks to some references (Battery university, Eletropaedia), I estimated the battery autonomy. I used an ideal estimation [=Battery Capacity/sum of power consumptions] and i supposed all the components worked 100% of the time.
The results i got is far bellow needed :(
Observations :
It seems that the pump is the only component to have an excessive consumption
Difficulties :
- Since, like i said, i have no experience in the field. I don't know if the battery i'm using is good.
- The pump seems to be necessary and irreplaceable. I talked to the mechanical team and replacing the pump with something else will make the project unrealistic.
- The 8 hours autonomy is a necessity to the project's success.
- The underwater environment.
- Dimensions (less than 8 inches long)
QUESTIONS : First, is the 8 hours autonomy doable ? what should i do to get that ? Change battery ? Change pump ? Use a totally different approach ?
Thank you for your time
