Do we decrease the the feedback fraction and increase the amplification fraction if we increase the value of L2? (similar to Colpitts oscillator where we by changing C2 capacitor)
- 21
- 6
Precisely, what do you mean by *amplification fraction*? – Andy aka Dec 28 '20 at 16:08
[This answer](https://electronics.stackexchange.com/questions/517675/how-does-the-colpitts-oscillator-reach-a-loop-gain-of-1/517814#517814) does a tear-down of the maths for a Colpitts Oscillator and you should be able to do the same for the Hartley if you follow that answer. It delivers the gain equation you might be seeking. – Andy aka Dec 28 '20 at 16:18
... Tank circuit gain magnitude is \$\frac{L2}{L1}\$ at the oscillation frequency for a Hartley. For a Colpitts it's \$\frac{C1}{C2}\$. – Andy aka Dec 28 '20 at 17:41
Almost -- but you want to decrease the value of L2. If you swapped the capacitors and inductors, then you would, indeed, decrease the value of the corresponding capacitor -- but inductive impedance goes up with increasing inductance, while capacitive impedance goes down with increasing capacitance.
It's more complicated than that. For any semi-reasonable starting point you decrease the feedback. But you don't necessarily increase the amplification -- you just increase the amplification that is needed. Just willy-nilly cutting the value of L2 (or adjusting the ratio of L2/L1 while maintaining the same resonance frequency) will eventually leave you with a dead lump of circuit that rings a bit when lightning strikes nearby but never breaks into continuous oscillation. Before that happens, you'll have an unreliable oscillator, or one with poor operating qualities.
- 44,867
- 1
- 41
- 104
Tim if I recall correctly the dominant part in the equation of amplification of the Collpits oscillator Xc of the capacitor connected directly to GND is dominant. – The Force Awakens Dec 28 '20 at 16:44
@TheForceAwakens you might want to clarify what your comment means. It doesn't make sense to me. – Andy aka Dec 28 '20 at 16:46
I am saying that the load impedance is equal to Xc^2/Re where Re is the parasitic resistance of the inductor and Xc is the capacitive reactance of the C2 capacitor which is connected to ground for a Collpits oscillator. – The Force Awakens Dec 28 '20 at 16:51
