I encountered some questions and problems I asked myself lately and hoped I can get a nice lead here before I start reading long articles without even be sure if it's the right way.
Let's assume I have an FPGA design, where I get ADC data with a sampling rate of 40MHz, so I latching the data from the ADC interface in 40MHz.
but I want to make the DSP inside the FPGA in 100MHz clock speed (for example because I have DDR3 memory interface in the DSP block diagram which working in 400MHz in 4:1 clock rate that means the UI clock of the DDR3 is 100MHz).
The data from the ADC interface which coming in 40MHz rate is 90% of the time valid, which means I need most of it.
So the first question I want to ask, How would you move the data stream from the slow to fast clock domain?
I already made a working mechanism for this, I filled up a FIFO (with 1024 depth) and right after that start to fill the next FIFO ( I used 2 FIFOs),
while the Reading process from the first FIFO starting at the moment the first FIFO is filled, and from this time on, I just read the 1st and then 2nd and 1st and 2nd and so on...
while keep to writing to the 2 FIFOs each at a time.
After I finished to write this block, I asked myself if there is a better way,
I encountered the Interpolation filter using FIR, does Interpolation make this job of moving from slow to fast clock domain for a stream of data?
I also saw the Polyphase filter which seems like also a way to move to a faster sampling rate.
Does its filter which easy to instantiate in FPGA is the right way to move the stream of data to a faster clock domain, or my way with FIFOs is the way to go?
thanks.
