-2
I have an Mi 18W 10000mAh powerbank 3 which I want to use for my project. I need 12 volt output. Although this powerbank supports 12V output, this feature is probably proprietary. A PD decoy module does not give 12V. I need power for a 12V LED strip in a portable photobox.
Is there some solution (decoy module or something) to make the Mi powerbank produce a 12 volt output? I didn't find anything.
JRE
  • 67,678
  • 179
Abedron
    If you are using that decoy module, make sure you soldered the jumper to tell it to ask for 12V. Better yet, also test the decoy module works against a different power supply. I'm not seeing anything in the spec page that says the power bank provides 12V Output when it is not being charged by a 12V supply. – Abel Dec 22 '20 at 15:41
  • https://www.mi.com/global/10000mAh-mi-18w-fast-charge-power-bank-3/specs – Abedron Dec 22 '20 at 17:14
    that's the spec I was looking at. It says "Output ports USB-A x 2" and later says "USB-A x2 5.1V2.6A" which could mean that the only only outputs on the USB A are 5.1V. The line that says "USB-A x1: 5.1V2.4A / 9V2.1A/ 12V1.5A (18W MAX)" has some fishy stuff. Either it's to cover their butts for failing to protect a USB-A port from 12V during charging via a 12V charger, or they meant USB-C in which case they would likely use some form of PD as it's part of the USB-C specs – Abel Dec 22 '20 at 18:16
  • Even if they had meant USB-C, they did not mention it as an output port so the spec makes no clear claims about an ability to output 12V. – Abel Dec 22 '20 at 18:34
You can use a step up DC-DC converter that has a 5V input, which would be far easier to do than trying to spoof a proprietary technology like PD or QC, which as the module you mentioned is not reliable or completely legal.
Adi
  • 189
    I looking for strightforward solution with maximum efficiety, withou DC-DC converter. Maybe for Mi powerbank not exist solution with some like decoy module. – Abedron Dec 22 '20 at 15:04
  • Correct. it will not exist. The protocol likely uses a hardware identification chip that is proprietary hardware by the manufacturer, and is usually protected by IP agreements. – Adi Dec 22 '20 at 15:09
Edit: Based on the spec you referenced, I believe the premise that "Although this powerbank support 12V output" is flawed. It supports 12V Input. This is from their spec page saying the outputs are only the USB-A and the images with the USB-C labeled as an "IN1"
If what you are looking at is the USB C power delivery spec that allows laptops to charge over USB C connector, how a device goes about negotiating that is part of the standard rather than 'proprietary,' although which profiles (particularly custom ones) a device supports and how may be.
How does a USB C port provide the power to charge laptops?
Abel
  • 456
  • Yes, for powerbanks with PD or QC suport it's easier, therefore is here my question for non standard Mi powerbank :) – Abedron Dec 22 '20 at 15:06
  • how do you know that "this powerbank support 12V" and it is NOT using the PD method? – Abel Dec 22 '20 at 15:28
  • https://www.mi.com/global/10000mAh-mi-18w-fast-charge-power-bank-3/specs PD or QC is not mentioned – Abedron Dec 22 '20 at 17:13
-1
If you use 5v charger for charging the powebank, it will give 5v as output. if you use 9v/12v charger for charging the powebank, it will give 9v/12v as output.
