The bit rate V baud rate has been a confusing topic for me lately. I feel like I am clear about the difference between these two.
But going through the definitions of baud rate, I find two different definitions in use:
  1. A baud rate is the number of times a signal in a communications channel changes state or varies. For example, a 2400 baud rate means that the channel can change states up to 2400 times per second. The term “change state” means that it can change from 0 to 1 or from 1 to 0 up to X (in this case, 2400) times per second. (This is the definition from my teacher's notes.)
  1. Baud rate as the no. of symbols transmitted per second. Consider a symbol "A" which is encoded as "0100 0001" in ASCII format. If I send this symbol within 1 second, I have bitrate of 8 bits per second.
For baud rate: According to first definition, baud rate is 1 baud per second.
But according to second definition, the baud rate is 3 bauds per second since the signal changes its state three times (0 -> 1 -> 00000 -> 1).
So how do these two definitions link together? I can't see any match between these two definitions with "my" level of knowledge. Thank you!!
And how is the calculation done in following image? I understand the calculation for the bit rate but how is baud rate calculated?
Transistor
  • 168,990
  • 186
  • 385
G-aura-V
  • 1,079
    The letter 'A' is not a symbol in this context. In this context, a symbol is a quantum of information that can be transmitted on the communication channel. – Elliot Alderson Dec 19 '20 at 15:20
  • @ElliotAlderson would you elaborate please? – G-aura-V Dec 19 '20 at 15:24
  • Sounds like a non-standard definition in the second one. "Symbol" sounds vague. I agree with Elliot's comment. It should be referring to the least indivisible information or something in the context you read. The first one is standard definition though. – Mitu Raj Dec 19 '20 at 15:49
    @Mitu Raj The terms *symbol* and *symbol rate* are not vague and have been in use for at least 40 years. – Peter Smith Dec 19 '20 at 16:37
  • @PeterSmith More than 70 years. Shannon himself defines them in his 1948 paper on information theory. Google says it's at 52485 cites, so you're right about well used. – user1850479 Dec 19 '20 at 16:42
    I would be curious to see any reliable source which correctly defines what is "Symbol" in information theory. As of the above definition of baudrate, does a Symbol means the same as "number of transitions of a signal" in a second (cz that's what baudrate means)? I don't think so. It has different meanings as per how the information is encoded. – Mitu Raj Dec 19 '20 at 19:31
  • on a parallel bus eg IEE1284 "A" as described in the question could be a symbol – Jasen Слава Україні Dec 20 '20 at 00:28
  • I am confused about the exact definition of symbol as well. Any reliable source would help!! – G-aura-V Dec 20 '20 at 01:40
  • You added an image. Baud means the number of signal state changes per time unit (seconds) as shown with the red level line in the time diagram. Bitrate means the number of bits per time unit (seconds). Each plateau in this diagram means a certain state of signaling. this state is often called a "symbol". It represents one or more bits, like the letter "A" on paper would mean 7 bits in the classical ASCII encoding. Writing down 20 such letters means a speed of 20 baud - but a total of 140 bits. – Alexander Stohr Dec 20 '20 at 09:48
  • The baud rate is also called telegraphy speed. In Morse telegraphy the symbols are from an alphabet with characters formed from dashes and dots but of varying length. (Thus a mathematically fixed translation formula is not possible.) Speeds are often given in characters per minute. Other levels of measuring are units of 5 grouped characters. (Might arise from transmitting encoded messages in military chiphered exchange.) Other measures might be word counts such as in billed telegraphy services across ocean lines. – Alexander Stohr Dec 20 '20 at 09:52
The letter 'A' is not a symbol in this context. A symbol is a recognizable distinct value on the communication channel; it is a quantum of transmittable information.
For a binary communication channel, a symbol is either a 0 or a 1. If you are talking about conventional UART kinds of transmission, then every transmitted byte of information will also need a start symbol and a stop symbol. So, you have to transmit 10 symbols in order to transmit 8 bits of information. The maximum information (bit) rate is 8/10 of the maximum baud rate.
Some kinds of communication can send multiple bits per symbol. In the old fashioned touch-tone dual-tone multiple-frequency (DTMF) telephone systems, pressing a button on the keypad caused a sound to be transmitted. Each sound was a symbol. Each sound comprised two audio frequencies, one frequency corresponding to a row on the keypad and the other frequency corresponding to the column. With four rows and four columns, each sound corresponded to 1 of 16 keys. So, each sound conveyed 4 bits of information.
Elliot Alderson
  • 31,192
  • 67
  • Actually, each button press transmitted *two* tones, hence the name "dual tone". – Hearth Dec 19 '20 at 16:09
  • So in this, a symbol would be 1 or 0? If that is the case there would be 8 symbols. So, 8 baud per second. Then how is it equal to 3 state changes in the signal? – G-aura-V Dec 19 '20 at 16:10
  • @Hearth You are right, I'll change that to something else. – Elliot Alderson Dec 19 '20 at 16:39
  • @G-aura-V You are comparing apples and cabbages. You talk about two completely different communication systems, one that encodes a single bit per baud and another that encodes three bits per baud. – Elliot Alderson Dec 19 '20 at 16:41
  • @Elliot Alderon I didn't get you. Which system in the question encodes three bits per baud? – G-aura-V Dec 20 '20 at 03:37
Data transmission has always some bits of overhead for giving the payload data a frame so that decoding it is possible with some certainty. Thus sync signals and also parity signals are there. On bus systems further multiplexing (routing) information is part of it. In modern systems there is even some parts used for data priorization (effectively part of the routing duty) and for media quality measurement such as DSL signal optimisation.
For RS232 you have for example the start and stop bits, and the optional parity bits - applied to each character bit (might it be 5 to 8 bits long). For Ethernet you have the whole IP header that encapsulates your payload data in a package. Further there are For CAN bus there is an address field and some checksums along with other bits. For bit-serial busses like I2C, SPI and alike you often will find read-write bits, address bits and also start/stop bits along with checksums and even feedback/confirmation/error bits.
Rationale: What's sent on the channel is more than just the data bits you want to be sent but also some extra data making it possible for the receiver to really decode your data bits. For this some extra bits are added and later on removed again. This extra bits are counted on the channel's baud rate but they have to be subtracted to estimate the maximum transfer data rate that you as a user will e able to achieve.
What else? Parallel busses have more than one wire and thus are able to transmit multiple bits per transmission step. Further the control flow is realized as separate wires. Thus an 8 wire + control flow wire interface can have 8 times the data rate than the baud rate.
The key word "symbols" is a term found in modem technology. With a certain signal shape more than one bit is encoded. This can be for example multiple tone signals send in parallel (DTMF) or other types of modulation (FSK, PSK, QAM, ...). Thus meaning the tone frequency and the switching speed between sent symbols (no longer bits) is quite decoupled. (Of course there is the Nyquist theorem of limiting a channel to some maximum raw data transmission capability.) So if you have for example 64-value quadrature amplitude modulation - then you will have a bit equivalent to those 64 values of useable channel capacity that is sent and received on each of the baud-rate steps. 64 values would mean 6 bits of raw data per baud-rate step. (Still even with this a few values might be reserved in order to achieve various types of bit and byte border synchronization as well as for channel duties.)
    Channel overhead is not part of the question (although it needs to be considered at link level). – Peter Smith Dec 19 '20 at 17:00
  • Good point, Peter. The question was not that clear for me if this item in the stack has even awareness - it definitely contributes in a larger amount of cases to the difference between user seen capacity and baud rate. - Further paragraphs on parallel busses and on /symbol/ based transmissions (or modulated signals) were there already. – Alexander Stohr Dec 20 '20 at 09:32
bit rate = (bits/symbol)*(symbols/second)
If you are going to transmit three bits at a time you have to use eight different frequencies (as in the case of FSK). So, each symbol will have three bits and the symbol rate (which we call baud rate) will be decided prior to transmission. This is your 'second' definition. For some modulation schemes such as ASK, BPSK, and PSK, the bit rate equals the baud rate.
Kaswechiha
  • 474
