I have gone through the Compact Model interface manual provided by Synopsys. They only mentioned to compile the .ccf file using cmi compiler and generate .so.arch file. However, there are no more details regarding this. I couldn't find much help from anywhere else. Hence, It would be really helpful if someone could guide me in this. Thanks
Asked
Active
Viewed 121 times
Helo, I am showing you here how to generated .so.arch file
first open your terminal window i am assuming that you have loaded all the synopsys commands needed. then go to the folder which you have .C file extension it is a c++ file(lets say filename.C) then invoke this command in your terminal windows as shown below
cmi -c filename.C
then it will generate filename.o
file in the same folder
then invoke this command as shown below
cmi filename.o
then it will generate filename.so.arch
files arch will be different depending upon your OS architecture for my case it is 64-Bit
so my generated filename will be as filename.so.linux64
I hope this will help you to generate what you are looking for.
Biki Teron
- 116
- 3
Thanks a lot. It helped. :) – Siddhanta roy Dec 14 '20 at 12:09
