I have a device that says it takes a "23A 12V" battery. I ordered a new battery and was mistakenly sent a "27A 12V" battery; same voltage, higher current. Is it safe to use this battery in the device, or will it break things?
Apologies for what must seem like a noob question; I'm not an electronics person. I have found a very similar question but it talks about capacity instead, and I'm not 100% sure whether that changes the answer or not.
ocrdu
  • 8,705
  • 30
  • 42
vvye
  • 111
  • Is your circuit fused to protect your wiring against extended over-current events? – Andy aka Dec 10 '20 at 11:44
    Does it say 23A and 27A or 23Ah and 27Ah on the batteries? – ocrdu Dec 10 '20 at 12:10
    Which device is in question? – Justme Dec 10 '20 at 12:16
    @Justme it's a simple electronic doorbell. it does say A, not Ah. – vvye Dec 10 '20 at 12:25
    A doorbell should not require 23 amps. Please give a link to product and manual. But this starts to look like how to use a product question. – Justme Dec 10 '20 at 12:37
  • @vvye: I suggest editing your question to "Is it safe to use an A27-type battery as a replacement for an A23-type battery" . Your issue has nothing to do with the current rating – Hilmar Dec 10 '20 at 13:31
    @hilmar that is the question. Changing the title makes no sense. – Passerby Dec 10 '20 at 16:09
    @Passerby: but the OP completely misunderstands the battery labelling. So the question as asked has nothing to do with their actual problem/issue. – Hilmar Dec 10 '20 at 23:14
    @hilmar so changing the question would do nothing for op and confuse it even more. The proper way to resolve it is as ocrdu did. Answer the question and problem. – Passerby Dec 10 '20 at 23:46
The doorbell application gave it away: 23A and 27A refer to types of battery, not to amperes.
It's an unfortunate marking some manufacturers use for A23 and A27 batteries, also known under many other names.
A 27A is 8 mm x 28.2 mm, a 23A is 10.3 mm x 28.5 mm, and both are 12 V.
If it fits well in your doorbell, then use it, otherwise, return it.
ocrdu
  • 8,705
  • 30
  • 42
    Thanks so much, that was it! It was indeed an issue of battery types after all, not currents. The 27A one works well. – vvye Dec 10 '20 at 16:56
