I planned to use SIM868 and what makes me confused all this time while choosing ESD protection is the voltage after clamping the transient voltage, it is still way too high especially when looking at ESD clamping characteristics graph. But first time I wanna tell you what have I done to solve this issue (indeed it still not solved yet).
According to SIM868 hardware design v1.07 page 37 they also include the recommendation part number for ESD protection, which is ESDA6V1-5W6 from ST or SMF05C from Onsemi.
After looking both datasheets, here is some basic information :
  1. ESDA6V1-5W6 : Vrwm 3V, Vbr min 6.1V, Vcl @ 8A is around 12V
  2. SMF05C : Vrwm 5V, Vbr min 6.2V, Vcl @ 8A is around 12.5V
Unfortunately only ESDA6V1-5W6 that has ESD response graph or maybe I can call it ESD clamping characteristics, the test is using IEC61000-4-2 air discharge +15 kV. The chart is in page 5 of ESDA6V1-5W6 datasheet, here is the screenshot :
ESDA6V1-5W6 ESD clamping characteristics
I am pretty sure it is 5V/div so it makes around 15V at the beginning of pulse and then stay at around 6V.
In that case, the voltage that will SIMCard interface see is 15V max and I think it is too way high for the interface.
Later on I also looking for absolute maximum rating for SIM868 and found it in hardware design v1.07 page 58 but there is no information about the maximum voltage that allowed to come in to SIMCard interface.
After that I looking for internal ESD protection of SIM868 and found it in hardware design v1.07 page 60, and again, there is no information about maximum voltage for SIMCard interface.
I think this is little bit the same with other data line ESD protection, maybe like I2C or USB but they need more small parasitic capacitance, so I use the search bar in Electronics StackExchange and found some answer.
  1. Using some series resistor, it will limit the current when overvoltage is occurs
  2. Using bypass capacitor to eat the remaining energy after clamping
  3. Using additional zener diode and series resistor
I believe all the advice above are working, but I think when it used to protect the data line I need to consider more about signal integrity, and I believe the best way for keeping the signal integrity is only using one protection.
So after all I wanna ask, is that OK if in such short time the SIMCard interface is exposed with more than its data line voltage level? (around 3V for SIMCard and exposed by more than 10V while ESD occurs)
For another ESD protection candidate that has lower clamping voltage I will choose PUSB3FR4 from Nexperia, but I little bit not sure about snapback voltage that can be as low as 1.5V, what do you think?
If you have any resource like article or some similar question, you can post it here, that will be a Great new information for me.
Please correct me if I wrong, Thank You.
cbagusjk
ESD diodes will dramatically reduce the effect of ESD pulses. You are right that the clamping voltage is still pretty high, but that is under specific test conditions that may not apply to your design.
What you should do is put in the ESD diodes, as recommended. For any data lines, you can add some series resistance (start with 0 Ohms) and maybe a capacitor, too right at the input to your IC, and then build and test.
If you pass ESD testing with no capacitor and a zero ohm resistors, great. But if you don't pass, then you have the option to put in the additional filter elements, and hopefully signal integrity will still be OK.
For the RF input and output signals, do not improvise. Do it EXACTLY the way the manufacturer recommends. No extra components, and no substitutions. The reason for this is that RF inputs are very sensitive to any change in impedance. You have to implement that part of the circuit as recommended, or you risk seriously degrading the performance of the GNSS system.
user57037
  • 28,915
  • 81
    Thank you for your advice. Maybe that is the last choice that we gonna do, do trial and error by adding some additional filter components. But as an Engineer, what is your consideration to choose ESD protection component for let say for protecting data lines, like maybe USB to SDCard? (in case your clamping voltage is way to high) Looking for clamping voltage as low as possible to meet your IC maximum voltage input? or reserve some space for additional filtering components? – cbagusjk Dec 09 '20 at 14:46
    There are ESD diode arrays specifically designed for USB. In general, if you attach one of those diode arrays to your USB bus, you will pass ESD testing and you will not have ESD damage in the field. It is not a requirement that the clamping voltage be lower than the absolute maximum voltage for the IC. What is required is that you pass ESD testing and have good signal integrity. The clamping voltage is a standard parameter of ESD and TVS diodes, provided for reference and to compare with other protection components. – user57037 Dec 09 '20 at 17:54
    Oh really it is not a requirement? That is new for me, all this time searching for Vbr or Vclamp as close as possible to the voltage level of protected device signal is the first thing I do when choosing ESD protection components, it gives more headroom to Vclamp to not exceed device absolute maximum voltage. I think this is the most important one when you are choosing ESD protection. – cbagusjk Dec 09 '20 at 22:37
    According to your answer " if you attach one of those diode arrays to your USB bus, you will pass ESD testing and you will not have ESD damage in the field ", is this included when Vclamp is higher than ICs absolute maximum voltage? ( I assume that this is also applied to SIMCard interface ) – cbagusjk Dec 09 '20 at 22:37
    Yes, even if Vclamp is higher than IC's absolute maximum. Because Vclamp is obtained in a laboratory test with the ESD diode only. Vclamp may not apply to your system during ESD testing (or field use). I cannot guarantee that it applies to SIMCard interface, but when the manufacturer recommends a specific ESD solution, probably it means that the manufacturer has tested it on other systems and it will probably work for you, too. – user57037 Dec 09 '20 at 23:52
    I think we must include the scenario when Vclamp applied to our system for the sake of safety, so in the end of the day reserve some space for additional filter is necessary like your advice above. Still, choosing Vclamp as low as possible is preferred, moreover when it is lower than Vclamp of manufacturer recommendation parts. Thank You for your advice and time! – cbagusjk Dec 10 '20 at 17:57
