I desiged P-MOSFET for reverse voltage protection, without gate resistor.
The reason that I tend to use it is protect from reverse DC voltage when someone connects the battery. Do I need a gate resistor? (When someone connects the battery correctly it will be in the ON state, otherwise the PMOS will be OFF.)
Second question:
How does a gate resistor reduce ringing?
Null
  • 7,448
Knowledge
  • 329
  • Show your schematic design; embed an image so everyone knows exactly what you are talking about. Battery voltage range and output current range values are needed. – Andy aka Dec 03 '20 at 11:33
  • its a simple voltage circuit protection with dc input that could connect from ATX Power supply(12v) its okay for datasheet... @Andyaka – Knowledge Dec 03 '20 at 11:49
  • Does [this](https://electronics.stackexchange.com/questions/68748/question-about-mosfet-gate-resistor) answer your question? – Rohat Kılıç Dec 03 '20 at 13:37
  • https://electronics.stackexchange.com/questions/287792/what-the-best-way-to-calculate-rg-gate-driver-for-mosfet/287805#287805 –  Dec 04 '20 at 10:16
0 Answers0
