I have a WWII era RAF chart-board lamp in perfect unused condition. I want to use an LED bulb with the original dimmer as tungsten runs so hot. I want to avoid rewiring or bypassing the dimmer as the original cabling is in such good condition.
The fitting for the bulb holder is BA15D, so I am limited in the range of 24V LED bulbs available.
The dimmer specs I can find are as follows:
- Ref 5C/726 type G
- Primary use: Chart-board lamp, 24 volt, 10 watts
- Total resistance: 50 ohms +/- 5%
- Number of turns each side: 95
- Wire: 0108 in. enameled eureka
How can I choose a bulb that will work?
