I would like to convert the LM317 circuit found in the accepted answer of this similar thread into its negative equivalent based on the LM337, in order to make a non-tracking +/- lab power supply.
Is it as simple as replacing the LM317 and swapping all polarities? I.e., starting from this schematic:
Update: Here is what I have for both positive and negative rails (including the generation of the +/-12V necessary for the JFETs). Is this correct?
I couldn't find the JFETs anywhere on Farnell or RS - I guess they're outdated. Could you suggest a suiting equivalent and why (so that I can learn from that)?
Many thanks
P.S: I am aware this is dissipating a lot of heat worst-case - I'll mount the TO-220 on a heatsink fan-cooled to get the Rth below 3°C/W and never touch the ICs. There is actually 0.5A out of those, 0.82R is supposed to be 2.5R.
