Imagine the following circuit with two capacitors and diodes acting as passive PFC.
My question is what is the capacity of these two capacitors? I mean compared to a circuit with just a single capacitor. Some people say they are in series so their capacity is halved, but I am unable to understand it.
As an example: Let's have 230 VAC, so we want to get approximately 316 VDC from AC-DC converter. We could use a single 400 V capacitor, let's say we take 10 uF. Without PFC. Now, if we use two capacitors instead, 200 V and 10 uF each, and connect them to this PFC circuit, the result will be just like having a single 5 uF capcitor? If this is truth I must be missing something, because I expect the capacitors are charged to 10 uF each and then discharged in parallel, so their capacity is actually added and only voltage is halved.
The reason why I ask this question here is that I read a review of one ATX power supply and the reviewer wrote that it contains a pair of input filtering capacitors in series, so their capacity is halved and it is insufficient. But as it was a passive PFC power supply, I expect this valley fill filter to be used there and I'd like to know whether the statement on halving the capacity is then correct.
Al Kepp
  • 2,971
  • 26
  • 32
  • Can you describe a scenario where the two caps would be discharged in parallel as shown? Also, this isn't a passive PFC circuit - it's a regular non-PFC design. – HikeOnPast Jan 08 '13 at 06:14
  • @HikeOnPast: When input voltage is lower than caps' voltage, the caps source the power to the circuit. Thanks to those three diodes around them, the current flows in parallel thru the caps. (The diode in the middle is closed, the upper and lower one are open.) – Al Kepp Jan 08 '13 at 07:10
  • You do see that the left capacitor will not be charged over Vr because of the diode above it? This is just two capacitors in series, so the capacity should be halved. The diodes are just there for protection. –  Jan 08 '13 at 07:26
I may not be obvious on inspection, but this is a very clever circuit known as a "valley fill circuit". Here are a large number of examples of them - images are live linked to pages.
Importantly - the diodes are NOT just there for protection - they provide a current steering mechanism so that the capacitors charge in series from Vin and effectively discharge in parallel into the load. When Vin valls to Vin_max / 2 the capacitors provide current to the load and "fill in" the voltage valley.
To answer the specific questions:
  • The capacitors are effectively in series when charged and the rules for series connected capacitors apply - so the effective capacitance is half what it would be if one capacitor was used - BUT the circuit needs two capacitors to work - see "Energy?" below.
Energy?:
Assign each capacitor capacitance = C Farad. Assign Vinmax the value V Volts.
If one cap of value C was placed across Vr then Vmax on cap = V so
enerrgy in cap = 0.5 x C x V^2 = C.V^2/2
Now place 2 caps of C each as shown in the diagram.
Each cap will charge to a max of V/2.
Current to charge them will flow from Vr through top cap, through hozizontal diode and then via bottom cap to ground.
Energy in one cap = 0.5 x C x (V/2)^2 = C.V^2/8
As there are 2 caps the stored energy will be double this =
C.V^2/4
which is half what we got before. If we used cap of C/2 in the original arrangement with a single cap energy max =
0.5 x (C/2) x V^2 = C.V^2/4 which is the same as for the 2 x C caps in series.
The REASON that energy is halved and effective capacitance is halved is that energy stored increases with V^2. Halving the voltage per cap reduces energy to 1/4 of original and havfing 2 caps brings the total back to 50% of before. Saying that this is equivalent to a single cap of half the value just means that, as we saw, that a single cap of C/2 capacity would have stored the same energy if it had V placed across it.
This circuit is a voltage halver.
I have seen circuits that have 3 caps in series with steering diodes to reduce Vout to Vin/3 and you could notionally extend this to N stages.
Here is a 3 stage valley fill circuit from here . This seem a tad mind boggling at 1st glance but is very straight forward. The 3 caps are series connected with joining diodes such that the diodes conduct when the capacitors are to charge from Vin. The tops of all capacitors are all connected via diodes to output (cap +ve to diode Anode) (top cap directly to output) and the bottom of all caps have diodes to ground (cap -ve to diode cathode) (bottom cap direct to ground). Extention to more stages would be trivial - with diminishing returns as losses increase.
Russell McMahon
  • 147,325
  • 210
  • 386
  • +1 Fascinating. p.s.: some more discussion of valley fill circuits: http://electronics.stackexchange.com/questions/25720/serial-capacitors-in-electronic-ballast-of-a-fluorescent-lamp – davidcary Jan 10 '13 at 04:07
