I am trying to create a D Flip Flop to use in a bidirectional 4-bit shift register, using Logisim. However, when using my D flip flop the shift register acts just as a normal register setting the bit for all 4 D flip-flops outputs instead of one by one. It works properly when using the D flip-flop provided by Logisim but I am wondering how to achieve this using my own D Flip-Flop.
This is the design of my D Flip Flop This is the design of my D Flip Flop
And this is the shift register (with the boxes representing the D Flip Flop) enter image description here
Any help would be greatly appreciated
Mitu Raj
  • 10,843
lilnut
D flip-flop provided by Logisim which you used for simulation was a positive edge-triggered D Flip-Flop. While what you have designed is a level-sensitive D latch.
You have to cascade two of those D latches in master-slave configuration to obtain a positive edge-triggered D Flip-Flop.
reference: Flip-Flops Wikipedia
Mitu Raj
  • 10,843
Shorten your clock pulse so that it is gone by the time the output data from one flip flop reaches the D input of the next. At the moment, with a long clock high time, when the new data arrives at a D input it is transferred straight through the flip flop and on to the next because the clock is still high.
This is a technique for producing a very short clock pulse, the duration of which is shorter than the time taken for the data to transition through the stage.
D type flip flop
    Unfortunately, even of you set the clock to `Ton` to 1 tick and `Toff` to 31 ticks, it still doesn't work. I suspect it calculates differently the states for the builtin D flip flop. – a concerned citizen Nov 18 '20 at 16:59
    @aconcernedcitizen yes, latches are different from flipflops. – user253751 Nov 18 '20 at 17:14
  • @user253751 True, but in real life you might get away with the inherent delays (also why you posted your answer). One of the reasons why I called it "concoction". – a concerned citizen Nov 18 '20 at 19:59
