I just bought a powerbank for intending of using it to power a Rasberry Pi4b
But, it seems i did not do enough research regarding the requirements of the Pi model i have.
The powerbank is listed as "2X 5V / 2.1 A" (it's got two usb outputs). (while the Pi in question appears to need recommended ~3A)
So, i'm thinking, rather than try to return it; I could either fashion a custom USB cable, out of- or similar to, the dual-(power)cords powering certain (older) external harddrives, having the Pi plugged into both of the USB outlets. Or, mod the powerbanks output, in the same way (removing one of the outputs)
But, i am a bit puzzled if i'm even reading "2X 5V / 2.1 A" correctly, as to mean those are two ports able of 2.1A each ? ..Or, if that is commonly the total given in such spec. listings ?
below is the powerbank specs from (Norwegian) manual if anyone's curious.
