Its fairly trivial to write a small .net console application that just stores serial port data to a file. Here is roughly what it would look like in Visual Basic.net. Obviously a complete program would include error handling and possibly command line options.
Module Module1
Sub Main()
'Open a log file for writing
Dim f As System.IO.FileStream
f = IO.File.OpenWrite("C:\SERIAL_LOG.bin")
'Open a serial port at 3Mbps
Dim p As IO.Ports.SerialPort
p = My.Computer.Ports.OpenSerialPort("COM1", 3000000, IO.Ports.Parity.None)
'Keep writing serial data to the file until the user presses the ESC key.
While Not (Console.KeyAvailable AndAlso Console.ReadKey().Key = ConsoleKey.Escape)
If p.BytesToRead > 0 Then
f.WriteByte(p.ReadByte)
End If
End While
'closer serial port
If p IsNot Nothing Then p.Close()
'close log file
If f IsNot Nothing Then f.Close()
End Sub
End Module
You can get one of the free versions of visual studio here.
https://visualstudio.microsoft.com/
You can fine the official documentation for all thing visual studio at
https://docs.microsoft.com/en-us/
After you are done capturing, you can then view the raw data in a hex editor/viewer such as HxD.
https://mh-nexus.de/en/hxd/
