I received SmallHD 5" display which was broken by supplying 14.4V by a mistake. It runs on 7.2V typically. The monitor is fine, just the backlight went bad. I replaced TPS61180 right off the bat but this didn't fix the issue. Right now I'm getting 15V on the output which is too low to drive 14 LEDs (7 in series, 2 in parallel).
I checked all caps and they seem to be fine. D1 looks good to me (can it affect the output voltage?).
I'm out of ideas for this one. The backlight is flashing once at boot and then it's off. I tried replacing the IC a few times, it's not the IC causing the problem. Do you have any idea or clue what should I check next? I don't know how LED drivers work so I hit the wall.
BTW. The part marked as Optional is not included in actual circuit.
