I'm following this project. More specific Step 7: Rainbow Pistil
https://www.instructables.com/Ever-Blooming-Mechanical-Tulip/
In the picture bellow. On the top left corner is how I should solder the leds.
- The upper ring(Brass Wire) is the positive voltage
- The lower ring(Brass Wire)
I am not sure if I should connect both 5V pin to the positive voltage ( upper brass wire) and the two GND pins to the GND ( lower brass wire):
The other uncertainty is connecting the led lights daizy-chained. Can I use the middle OUT pin of one LED and connect it with the middle IN pin of the other LED.
I have tried to find a solution regarding this but there is no explanation when it goes to connect them to a brass wire..
