I am relearning VHDL and have a question about the code below. This is from a tutorial I have been following. When a button is pressed, an LED gets turned on after the person releases their finger from the button. I am confused about the order of execution in the process. Specifically this line: if i_Switch_1 = '0' and r_Switch_1 = '1' then
I have been reading that inside processes the code is executed sequentially, so I do not understand how this gets executed, since they are assigned to the same value right before.
Thanks
library ieee;
use ieee.std_logic_1164.all;
entity Clocked_Logic is
    port(
        i_Clk : in std_logic;
        i_Switch_1 : in std_logic;
        o_LED_1 : out std_logic);
end entity Clocked_Logic;
architecture RTL of Clocked_Logic is
signal r_LED_1 : std_logic := '0';
signal r_Switch_1 : std_logic := '0';
begin
    p_Register : process (i_Clk) is
    begin
    if rising_edge(i_Clk) then
        r_Switch_1 <= i_Switch_1;
            r_LED_1 <= not r_LED_1;
        end if;
    end if;
end process p_Register;
o_LED_1 <= r_LED_1;
end architecture RTL;
Eric33
  • 83
    you are dealing with hardware, not software ... there is a delay between input states and output states – jsotola Nov 06 '20 at 19:48
    Signal assignment semantics and delta cycles. https://stackoverflow.com/questions/13954193/is-process-in-vhdl-reentrant/13956532#13956532 –  Nov 06 '20 at 19:49
    The answer to this question is teaching the basics of VHDL and it's a Q&A site, not a step-by-step tutorial or discussion site. I won't write an answer because there's tons on the internet. But... Get yourself away from the trap you've walked into: seeing VHDL as a programming language that executes software instructions. It's a descriptor language for describing the behaviour of digital logic circuits. It behaves very differently. Signals are not program variables, they are scheduled in a simulator and circuitry in a chip. It's for you to teach yourself the basics. Good luck with it, enjoy. – TonyM Nov 06 '20 at 19:56
  • There is no "execution", as these are hardwares. Btw you can learn C/C++ in 2 months but not HDL languages cz there are more to it. Good luck – Mitu Raj Nov 07 '20 at 16:53
Here is essentially what the hardware looks like. The i_ prefix means input or intermediate signal to a register. What you have is one register for detecting a falling edge on the Switch_1 signal and another register for toggling the LED output whenever a falling edge occurs on the Switch_1 signal. Note that wrapping the output of a register back to the input through a NOT gate creates a toggle flop. The toggle flop is enabled (toggles) whenever a falling edge occurs on the Switch_1 signal.
mrbean
  • 683
  • Sorry, I accidentally left that out. @TonyM is correct, the i_CLK signal in the VHDL code should be connected to the CLK inputs of the registers in the drawing. – mrbean Nov 06 '20 at 20:10
  • Yup all done! Fixed a copy and paste error with the LED register too. Thanks @TonyM – mrbean Nov 06 '20 at 20:23
