I am willing to manufacture a PCB from China, but I am wondering how much the cost will be deference between double-sided or single-sided assembly, rough estimation will help.
Thanks
Thanks
It will depends on your PCB complexity number and size. But they will be pretty much the same price.As they have the same complexity to produce.
Here is an example from PCBway
1 Layer :
Assembly will depend on the stencil price, usually around 100-200$ in my experience.
The one off cost will be much higher.
Once this is paid for, the cost per PCB assembly will be only a little bit higher but not so much.
Cost of PCB should be the same.
Use this solution only if board area is limited.
