Based on this topic and the connection that is proposed I would like to make two questions (if somebody has face the same problem/task). So can I connect the data cable to a raspberry GPIO and then the voltage and GND to an external power supply or I would have problem with the pull up resistor? Also, is it ok the last sensor to be 30 m far from the raspberry? or I would have reflections problems? I am thinking of using cat5 cable. Is it a good choice?
Asked
Active
Viewed 287 times
Ah, 30m is a bit long. You might like to consider DS2482: (1) DS2482 I2C to 1-Wire Bridge Connecting 10+ DS18B20 Temperature Sensors Using 30 Metres Long CAT5e Cables, Viewed 699 times https://raspberrypi.stackexchange.com/questions/111412/rpi3b-python-ds2482-i2c-to-1-wire-bridge-connecting-10-ds18b20-temperature-sen/111421#111421 (2) DS18B20 Temperature Sensor - Rpi 3/4 Driver, Wiring, Detection, and Python Programming - Viewed 1k times https://raspberrypi.stackexchange.com/questions/100203/ds18b20-temperature-sensor-rpi-3-4-driver-wiring-detection-and-python-progr. Cheers. – tlfong01 Oct 28 '20 at 13:54
It depends, cable rise time, 1-Wire topology and length, check https://www.loxone.com/enen/kb/wiring-1-wire-devices/ – Mats Karlsson Oct 29 '20 at 20:19
What relay? The question is only about One Wire and DS18B20!?!?! – Mats Karlsson Oct 31 '20 at 14:36
You are right. I deleted the comment – hmmy92 Nov 04 '20 at 14:19
