Supposed I have 3 resistor, R1=1 Ohm, R2=2 Ohm, R3=3 Ohm. I connect them with copper wire to form a ring R1-R2-R3-R1
I used a device to generate changing magnetic flux in that ring. So there must be induced current flow in the ring.
The problem is if I measure voltage between two ends of R1, what would that voltage be ? Since it is closed circuit then Ohm law indicate that I *R1 = I * (R2+R3)
EDIT: As suggested in comments, this question duplicate Can two voltmeters connected to the same terminals show different values? Circuit with induced EMF
