I have a few FTDI FT232H breakout boards from Adafruit. I wanted to connect multiple of them through a USB hub. I was under the impression that the serial number is unique and based on "The serial number consists of 8 characters, the first two being the manufacturer ID and the next 6 being base 36 numbers based on the date and exact time of programming." as per https://www.ftdichip.com/Support/Knowledgebase/index.html?howistheautomaticserialnu.htm.
But when I run my code to identify the devices. I see
Channel number: 0
Description: FT232H
Serial: FTKIJX5M
LocId: 13377
Channel number: 1
Description: FT232H
Serial: FT3ZQ7NY
LocId: 214084
Channel number: 2
Description: FT232H
Serial: FT3ZQ7NY
LocId: 36
Channel number: 3
Description: FT232H
Serial: FTOVSJUB
LocId: 35
Channel number: 4
Description: FT232H
Serial: FTOVSJUB
LocId: 13378
As you can see I have two FT3ZQ7NY, and two FTOVSJUB, and one FTKIJX5M, is there a way to make it unique because all my devices and attached peripherals are identical in nature. Is there any way to uniquely identify the device?
sandeepzgk
  • 209
The best way to solve it to program the FTDI chip using FT Prog that you can download from https://www.ftdichip.com/Support/Utilities.htm#FT_PROG
  1. Select the device in the device tree
  2. Select the USB String Descriptors
  3. Uncheck Auto Generate Serial Number
  4. Enter a Custom Serial Number
  5. Click on the program button (which looks like a lightning bolt in silver color)
Now you can get it in unique numbers, or you can auto-assign the serial numbers based on the unique timestamp of programming.
Channel number: 0
Description: USB <-> Serial Converter
Serial: FT58FK0A
LocId: 13377
Channel number: 1
Serial: FT58FK0B
LocId: 214084
Channel number: 2
Serial: FT58FK0C
LocId: 36
Channel number: 3
Serial: FT58FK0D
LocId: 13378
Channel number: 4
Serial: FT58FK0E
LocId: 13378
sandeepzgk
  • 209
    Note this may not work with counterfeit (not genuine FTDI) parts. –  Oct 28 '20 at 15:27
