I was thinking of buying a Residual current device but I don't know if the power supply to my home is grounded properly or not. For initial testing I used my multimeter to check the voltage coming to my home. It was 220 V.
Then I checked each terminal from the power switch and compared it with the ground ( Had a metal rod dug very deep in the ground).
It was 217 V with respect to the hot wire and 3 V with respect to the Neutral Wire.
I was expecting to be a 0 V difference with respect to the Neutral wire. But it was constantly showing 3 V. I checked it many times.
Now, my question is,
- Am I measuring it correctly? Is there any flaw?
- Will the RCD trip in current situation?
- Should I go ahead and buy one? If not then is there any way to fix the situation or any other device like RCD for the current situation?
PS, I even used the multimeter to check the continuity of the Neutral wire with the metal rod. It did not beep.
