Assuming no load, how does continuously changing the distance between the plates of a capacitor (in a sinusoidal fashion for simplicity) affect the output voltage? Does electromagnetic induction come into play in this scenario?
I understand there will be an immediate change in the output voltage since $$ V = Q/C = \frac{Q}{\varepsilon}\frac{d}{A} $$ and clearly the permittivity constant will change sinusoidally itself.
But what about the fact that there is a time-changing electric field? We must have a perpendicular time-changing magnetic field as a result. Does this magnetic field affect the voltage across the plates?
If not, I believe that would mean the energy spent in changing the distance would be dissipated purely thermally.
(For clarity, this is not a question from an assignment or such.)
  • In practical terms that depends on how fast you do it... eg, yes, there is, but if you do this with any sort of ordinary motor driven apparatus it's probably not significant. Given one can pick up mains AC fairly easily it's probably *detectable*, with careful mechanical design you could even reach VLF frequencies, but beyond that... – Chris Stratton Oct 21 '20 at 14:31
    Not sure - but this is the operating principle of electret microphones, so possibly the modelling of those may have some hints – pjc50 Oct 21 '20 at 14:40
    Back in the day, there were rotary variable capacitors (usually used for trimming or mechanical tuning). These varied A instead of d, to the same result. Remember farads are coulombs per volt, so if the charge on the cap isn't changing, the voltage will vary inversely with the capacitance. Interestingly, if you reduce C by changing the distance, the voltage will increase, but the field strength will stay the same (volts per meter). – Cristobol Polychronopolis Oct 21 '20 at 15:53
A practical plate capacitor has a part of its field bulged out of the gap and that part becomes more significant as the distance of the plates grows. The bulged part doesn't stay constant if the distance of the plates oscillate. That generates oscillating magnetic field as J.C. Maxwell wrote in his famous compilation theory of the electricity. It can also cause significant radiation if the gap is long enough and the gap oscillation frequency is high enough. Otherwise a charged but unconnected capacitor (even no wires) acts like a tensioned spring which dissipates nothing when one pulls the plates further apart.
If there's wires the system is complex. The wires are a load and there's AC current between the plates and wires. That causes losses if there's resistance and the needed mechanical oscillation frequency for substantial radiation becomes lower although not necessarily practically realizable.
