When mapping symbols of various modulation constellations, Gray code is used such that - each adjacent symbol only differs by one bit. Why do we want small physical changes in the signal to correspond to small changes in the symbol ? Why not use binary mapping ?
Asked
Active
Viewed 841 times
1Using gray code means that in the presence of an incorrect slice/demap it's more likely only one bit will be wrong. If you used binary, you might get two bits wrong in such a case. Given the improved probability of getting only one bit wrong using gray coded symbols, the addition of error-correction codes is now also more meaningful as they can be easily designed to correct single-bit errors. – jonk Oct 21 '20 at 03:23
Because of noise and channel distortion.
Any noise or distortion would result in a change in amplitude and phase of receiving symbols. So for instance in 16-QAM with 4-bit words, if an amount of distortion causes a symbol to place in the adjacent room, we will have only one bit error while other 3 bits are ok. In this case if we use binary sequence, the same amount of distortion could end up more losses, even the all bits of the symbol.
Hamid R. Tanhaei
- 827
- 4
- 5
1So in other words it's done to make the job for the FEC module easier ? – shaiko Oct 21 '20 at 08:05
Yes, using Gray code reduces the overall error rate with respect to the case of using normal-binary code. And of course, makes error correction process much more easier. – Hamid R. Tanhaei Oct 21 '20 at 08:29
