UL 1971 27.1.3(a) requires that listed strobes used for fire alarm signaling to hearing-impaired occupants flash at between 1 and 2 flashes per second:
a) Signaling lights shall produce a candela output in effective intensity in accordance with Tables 27.1 – 27.3 and Figures 27.1 – 27.3. The flash rate shall not be less than 1 hertz or greater than 2 hertz over the rated operating voltage range.
However, in practice, UL 1971 listed strobes, such as the System Sensor L-Series, are produced with a specified flash rate of 1 flash per second. This raises a question: is there a measurement tolerance on the 27.1.3(a) flash rate requirement, or does the listing process for these strobes require the flash rate to be strictly between 1 and 2 Hz over the operating temperature range, time (when the strobe is free running), and any unit-to-unit variation that may be present?
