I am reading this paper and I see that characteristic impedance does not take frequency into account. I am surprised by this as I figured different rise time signals would have different frequency content and see different impedances. Z0 is proportional to sqrt(L/C) and I figured those values change at different frequencies.
Are these characteristic impedance equations only valid for certain frequency range or am I wrong in assuming that characteristic impedance will have a frequency dependency?
https://www.polarinstruments.com/support/cits/IPC1999.pdf
EasyOhm
  • 4,609
  • 26
  • 35
    Yes, there's a small frequency dependence, because \$\epsilon_r\$ varies a bit with frequency. – Spehro Pefhany Oct 15 '20 at 21:11
    As f increases and dielectric constant decreases , thus Zo increases and load RC affects bandwidth of transmission line. Thus selected substrates for microwave logic (CML) and radio signals may use Polyamide, ceramic or Teflon and a wide range of better dielectrics than just FR4 epoxy/fibreglass with Dk=4.2 and effectively reducing with higher f. I tended to use w/h ratios =1 for most to get near 50 Ohms for 74HC logic and 25 Ohms for 3.6V logic demands thinner insulation layers than normal to raise the w/h >1 or reduce h/w<1 – Tony Stewart EE75 Oct 15 '20 at 21:19
At frequencies above about 100 kHz to 1 MHz, the characteristic impedance can be said to be \$\sqrt{L/C}\$ but, this doesn't account for lower frequencies where the characteristic impedance is: -
$$Z_0 = \sqrt{\dfrac{R+j\omega L}{G+j\omega C}}$$
Where R is the series resistance per unit length and G is the parallel conductance per unit length.
  • So, at really low frequencies we can say that \$Z_0\$ is \$\sqrt{R/G}\$.
  • At mid-audio frequencies we can say that \$Z_0\$ is \$\sqrt{R/j\omega C}\$.
Here's an example of telephone cable that I calculated myself using excel: -
Extracted from my answer here.
It has a frequency dependency for sure but, for track impedance calculations we are normally only interested in frequencies that are significantly above 1 MHz hence, \$Z_0 = \sqrt{L/C}\$.
