The tip speed ratio is given by TSR = w.R/v where w = rotational speed of the turbine, R = radius and v = wind speed. Now the speed of the tip is a function of the energy extracted from the wind, but the energy extracted from the wind is also a function of the TSR.
- Under a no-load condition, the turbine is free to spin, and I would imagine that the TSR is a simple function of the pitch angle. The TSR should be able to go right up to the value dictated by the Betz limit.
- Under loading conditions, the rotational speed of the generator should be such that the power output from the turbine is in equilibrium with the marginal load in the system, and therefore the TSR is a function of the rotation speed, and therefore the output of the WT.
If the above thinking is correct, then what is the use of the TSR or the Cp in wind turbine calculations? Aren't they determined by the external load, and not by the wind turbine design, under loading conditions?
