Happy new year all!
I'm wondering how to correctly use the reference pin on an INA128 Instrumentation Amplifier. Is there a way to use this pin to eliminate negative voltages (i.e. do a voltage shift)?
Thanks again.
user1883691
  • 117
    Yes, you can do a voltage shift through InAmp's REF pin. A [very similar question](http://electronics.stackexchange.com/a/52626/7036) was posted today. – Nick Alexeev Jan 01 '13 at 04:14
  • Thanks, that's what I am looking for. In the schematic on the reference section, how would you add the decoupling cap and what value? – user1883691 Jan 01 '13 at 04:28
  • Using this pin wrong can kill your CMMR, so be a bit careful. – Scott Seidman Jan 01 '13 at 12:51
The reference pin is exactly for level shifting the output. Note that it is best to use a low impedance source for this.An op amp as a unity gain buffer or other configuration should ideally drive this pin.
For decoupling take a look at the typical application circuit in the datasheet. It recommends a 0.1uF capacitor. Perhaps an extra 10uF capacitor would also be good.
Gustavo Litovsky
  • 7,619
  • 44
