I'm trying to get a regular ph reading in an aquarium.
The sensor works well when the probe is in a small quantity of water(i.e. a glass) but has large variations in larger water quantities (i.e. aquarium).
The circuit uses an ads1115 and a node mcu.
I'm looking for suggestions on what i can do to reduce the interference. Here's what i've tried:
- adding capacitors between gnd and vcc on the probe controller board.
- different usb cables / power sources
- unplugging all other electrical devices in the vecinity.
- moving the cables around as to not intersect any power cables.
- adding ferrite corea to both ends of the ph probe.
- adding ground connection to the bnc connector.
Here's what it looks like and what values i get. The part where it stabilized is when i moved the probe to a glass of water in the same location.
