I would like fo know how do thermal pads work, more specifically why does their thickness matter so much even more so than their actual conductivity numbers sometimes and how do I choose the proper thickness, or rather how do manufacturers choose it for the various products/applications.
2*Thermal pad* is a vague term. Do you mean a sheet of material that goes between the part and a heatsink (or copper on a PWB used as a heatsink)? – Mattman944 Oct 11 '20 at 22:43
Both that and thermal pads for example on top of PCB modules, VRAMs, VRMs etc, but ultimately thermal pads that dissipatiate heat. – appwizcpl Oct 11 '20 at 22:49
2Your comment made the question more vague, not less. Do you know how to calculate the temperature differentials for the conductive path? This is fairly straightforward. The convection from heatsink is more complicated. – Mattman944 Oct 11 '20 at 23:14
Thermal pads work basically on the basis of the fact that they're more conductive then the material they replace (air).
They don't work too well because they generally need be soft enough to conform to the surface they're trying to mate, which places limits on their composition.
Basically, you want the thinnest thermal pad you can manage. The obvious end-point for this is thermal paste (where the thermal paste can squeeze out allowing the thinnest bond-line possible).
Generally, you design for the thinnest gap possible. You only go thicker due to mechanical constraints.
Thermal pads are basically a compromise that you only take due to mechanical constraints. They're generally never better then a mechanically clamped interface with thermal paste. A thermal pad provides assembly convenience (and substantial gap filling in some cases), but poorer performance.
This is pretty apparent if you consider it a bit. If you reduce the thickness of a thermal pad by 1/2, you've effectively cut it's thermal impedance by half, which would require double the thermal conductivity to equal. It's much easier to thin the thermal pad then to improve the thermal conductivity beyond material limits.
In any application I've seen, thermal pads do not dissipate heat. They move heat from a device to a dissipative radiator.
Making a heatsink out of thermal pad material would be silly, because they're really quite crappy in terms of actual thermal conductivity.
- 31,938
- 6
- 77
- 137
You say they move heat from a device to a radiator, but what if there is no radiator. E.g. thermal pad on a NVMe drive? – appwizcpl Oct 12 '20 at 06:54
1It's not going to do anything substantial? Fortunately, most NVMe drives have heat spreaders (which are basically really crappy heatsinks), rather then just thermal pads. – Connor Wolf Oct 15 '20 at 23:51
So a thermal pad can act as a really bad passive heatsink? If that is the case what thickness is better, if we are comparing 0.5mm, 1mm, 1.5mm and all the up to 3mm? – appwizcpl Oct 19 '20 at 07:06
1No, my point was that the things on NVMe drives aren't *just* thermal pads, there's copper embedded in a lot of them. And the thickness of a material used as a heatsink has no effect on it's utility as a heatsink, it's entirely a function of it's surface area. If you're trying to use a thermal pad as a heatsink, well, 1: why, and 2: a thicker thermal pad would mean slightly more surface area, but the poor thermal conductivity of the pad material would lead to diminishing returns probably fairly quickly. – Connor Wolf Oct 19 '20 at 09:42
1Basically, anything that's exposed (generally to the air, though radiative thermal transfer is also a thing) and not at ambient temperature *is* a heatsink, at least to some extent. It's not like you *only* get thermal relief from the thing you label "this is the heatsink". You have to think in the context of thermal energy transfer in a entire system. – Connor Wolf Oct 19 '20 at 09:45
(1/2) Sorry for the late reply, but I have came to a weird use case and I would like to understand this in practical terms. I have a laptop (TP T480) which has no GPU, but I want to use a heatsink for the same laptop with a GPU, so it fits perfectly, just improved cooling! However, where there should be a heatsink connecting to a GPU, it is only a heatsink barely touching a PCB. If I were to use a thermal pad, to prevent shorting the motherboard, would that have any negative impact temperature wise, or will it actually worst case just be neutral in terms of temperatures on the PCB or the CPU. – appwizcpl Nov 12 '20 at 22:19
(2/2) I could use a kapton or a sctoch tape, on both the PCB and the heatsink, but this will not protect the PCB components if there was just a very slight bend on the motherboard, which actually might be impossible, but just in case. That will surely not effect the temperatures, but I can also use both a kapton and a thermal pad, but again I would not know how will a kapton affect the conductivity when pressed upon a thermal pad. – appwizcpl Nov 12 '20 at 22:22
