When you apply a voltage to a insulator if the insulator is shaped appropriately its shape is changed.
When the piece of insulator returns to its initial state a voltage is generated by which is its polarity compared to the original voltage?
The voltage is related to the amount of mechanical strain/stress in the material and is a dynamic equation (has states changes over time):
Source: https://onscale.com/piezoelectricity/the-behavior-laws-of-piezoelectricity/
In short: to calculate the voltage generated, one needs to know
When the piece of insulator returns to its initial state a voltage is generated by which is its polarity compared to the original voltage(step 1)?
Without getting too deep into the equations, the stress in the material starts to generate an electric field (the electrons have to be there in the first place). This then generates a voltage (and reduces the strain). If the strain is held steady then the voltage will be steady ( they build strain gauges with piezo electric materials). As the material relaxes, the voltage of the material falls (zero strain = zero voltage). So if the material is relaxing the voltage doesn't reverse, it falls toward zero. If you wanted to get a negative voltage, then you'd need to pull the piezo electric module instead of push it.
