I use this step down converter with input 30V DC and output set to exactly 5V. At the output I connected an ESP8266 (WEMOS D1 mini, has 3.3v regulator on its board) and an MP3 player module (DY-SF5W.) One thing is, I experience sparking on the input side of the step down converter module whenever applying power to it. But more concerning, I destroyed my load at the output (the MP3 player module DY-SF5W.)
I set the output to exactly 5V and connected the ESP8266 and the mp3 module to the output of the step down module. After powering up the step down converter 2 or three times (30V DC at the input), the mp3 module was destroyed. The microcontroller on the mp3 board smoked and you could see it glowing. The voltage was definitely set to 5V, and the ESP8266 was still working ok. I then connected another MP3 player board/same model, which first worked ok, but again after 2-3 times powering up the input of step down converter, again the uC of MP3 player board smoked exactly as the first one. The ESP8266 again survived.
I then monitored the output of the step down converter closely with oscilloscope, all looked fine, but after setting time base to 25ns, I could see that at the moment when connecting the input voltage to the step down regulator, its output VCC spikes to plus 18V and down to minus 10 volts, but only 25-50 ns in length, and then back to 5V. The question is, is it possible that this very short Vcc change is dangerous to certain parts, and why I do not find more results when searching google for damages due to that? Even with a 4700uF cap at the output of the step down, I sometimes get those spikes. Another step down converter module of same type shows the same spikes. How can I securely get rid of them?
JRE
  • 67,678
  • 179
    Any spike above abs max Vcc MAY destroy a device. YMMV . || Try: Input series resistor with cap on LM2596 side. || Zener on output with voltage JUST above desired Vout. It has been suggested that modules such as these often use inductors that saturate at high loads and low grade caps. | At startup output cap must charge and inductor may saturate briefly. [LM2596 data sheet here](https://4donline.ihs.com/images/VipMasterIC/IC/NATL/NATLS05772/NATLS05772-1.pdf?hkey=EC6BD57738AE6E33B588C5F9AD3CEFA7) – Russell McMahon Oct 06 '20 at 22:22
    Size Rin to drop a few volts at Imax. Aim is to get slower turnon and limited initial current. May not help :-). Output zener purpose obvious. Larger Cout MAY make things worse. Or not. Depending on actual mechanism. ie above may be wrong. – Russell McMahon Oct 06 '20 at 22:24
    Obviously this cheap converter does not behave well to hot insertion step loads as it has no OVP and yes that exceeded your load Breakdown voltages and fried the parts. This appears to be from under voltage on contact forcing full drive with high ESR poor output caps that did not integrate well. The low ESR input cap causes the arc on contact. Lesson learned. Do NOT use dry contacts to connect a cheap step down regulator to load. Connect first before powering up ! – Tony Stewart EE75 Oct 06 '20 at 23:12
    The pulses that are only a few 10's of nanoseconds wide may not be real but due to the way you are probing it. With reasonable decoupling capacitors at the load they should get through and cause any damage. Can you show how you wired it up or even a picture. – Kevin White Oct 07 '20 at 00:47
  • (1) I agree with @Russell McMahon that delayed start up might help. (2) Your Vin = 30V might be a bit too high for eBay goodies which are badly tested. (3) If you try Vin = 12V and still have the same problem, I might try to repeat your situation and see what happens. (4) LM2596 App Note - https://i.imgur.com/GIggbvq.jpg – tlfong01 Oct 07 '20 at 01:46
  • I can't easily see a datasheet on your MP3 module. Do you have a link? – Chris H Oct 07 '20 at 08:13
  • One point: maybe start troubleshooting this with dummy loads instead of MP3 modules. – user253751 Oct 07 '20 at 09:45
  • Q1 What is the load current profile? eg steady max current, max short peaks, max spikes. EXAMPLE ONLY A load may draw 300 mA for 10's of seconds on transmit, 500 mA for <= 200 mS in some cases (eg WiFi TX peaks) and maybe 1A for under 10 uS (eg shoot through on a poorly designed H bridge). – Russell McMahon Oct 07 '20 at 10:44
    A connection diagram / circuit dioagram is ALWAYS a good idea. Word pictures can often convey incorrect impressions. Your latest comments in your answer re MP3 board only connecting a speaker is highly ambiguous. Is the MP3 board unpowered? If powered how is it's power supply associated (or not) with this supply. etc. – Russell McMahon Oct 07 '20 at 12:26
6 Answers6
The spike problem may be due to a "lag" in feedback (resistor-dividing) circuit. It means there's a delay between feedback voltage and output voltage. If you have added a capacitor in FB (Feedback) pin, remove it. If the problem still exists, add a small cap (in nF range) between FB (feedback) pin and output voltage.
When you connect your power supply, a spark happens (due to the charging of buck converter input capacitors.) If you will check on the oscilloscope this voltage goes up to 300 - 500 volts for a fraction of a second. It causes the destruction of your LM2596 buck converter.
To protect, change your circuit to the following:
Use a 2 watt resistor at least. I use this technique in my E-Bike when powering aux at 48V and it works.
JRE
  • 67,678
  • 179
Deepak
  • 896
  • That's interesting. Does this just limit the current when charging the capacitors? Why use the 1N4007? Wouldn't it burn out due to the high amount of current? For what it's worth, my buck converter circuit that I made drew 4.2 amps on startup. I didn't have any protection like this. – BestQualityVacuum Oct 07 '20 at 04:10
  • Yes, it limits the current, but use this carefully. As the user gives 30V input and 5V output, current reduction to the input is 1/6. So it is safe to operate this way. If at such high voltage your current is high then there are other way to protect from spark. – Deepak Oct 07 '20 at 04:19
Are you using the LM2596-Adjustable or the LM2596-5V version? The measurement might be wrong or the curent changes. This regulator supplies as much current as you request. I have had problems burning strips of LEDs, because there was no current limitation.
Also these chinese devices are not very good.
winny
  • 13,064
  • 63
CFCBazar
  • 501
after setting time base to 25ns, I could see that at the moment when connecting the input voltage to the step down regulator, it's output VCC spikes to plus 18V and down to minus 10 Volt, but only 25-50 ns in length
If there are decoupling capacitors on that rail voltage, it is very suspicious to measure a 50ns spike that goes 13V over the output voltage. I bet that's common mode noise due to the spark and inrush current being displayed by the scope. See this answer for details.
Note these cheap "LM2596" modules are usually fake and counterfeit. Sometimes they don't even bother to fake the National logo and font right, and the chip isn't even a fake LM2596 since it runs at the wrong frequency. Probably some other chip being relabeled. Eventually the low quality, high-ESR output cap will die and output voltage ripple will go out of control, but that shouldn't happen when it's new.
Solution: replace counterfeit DC-DC with good brand, see this mouser search link for example. You can find canned DC-DCs for a few $.
Now your ESP8266 survives but your MP3 player dies. The fact there is some 30V around hints that's a power supply for an audio amplifier that is connected to the MP3 player. Presumably this signal connection also has a ground.
So there is another possibility: a ground loop. You say there is a spark when connecting LM2596 power input, which means you do it by hand with wires. If the power connection is established before the ground connection, or the power ground connection gets loose, then current will find its way through the signal ground between the MP3 player and the power amp. Depending on the path the current takes on the board this may damage your device, or cause it to latch up and burn. So you should make sure ground is not interrupted, check for loose breadboard or connector contacts, that kind of thing.
bobflux
  • 70,433
  • 83
  • 203
Seems like a surge/transient, ESD problem or maybe your supply to the step down converter gives a overshoot during stepload or just isn't stable.
Anyway a proper varistor or serveral ones should clamp the over voltage if done correctly. I would also advise you to put TVS diodes on the output, if the component is disconnectable(as it seems they are) to avoid ESD.
user103776
  • 616
I put a resistor of 22 Ohm in series to the input of the step down, which removed the biggest spikes at the output, and also the sparks when connecting input power to the step down. now the spike is max 7 volts for 50ns, and no more negative voltages at output of step down. maybe I use an additional voltage limiting Z Diode circuit at the output to prevent those very short over voltages. Will try that. Regarding the ground path remarks, the mp3 board was not connected to other grounds, it simply had a speaker connected to the amp output. In fact there were only three wires to the mp3 board: GND, VCC, serialTX from ESP8266.
Thanks to all for the valuable remarks
  • Q2 What capacitor do you have at the IC input and output? Q3 How are you switching the supply when you see sparks? (Switch, plug in wire ...) – Russell McMahon Oct 07 '20 at 12:23
