It's just like another component placed on the anti-static mat, right? This should work at providing an inexpensive heat-resistant and anti-static workbench area?
All the 'anti-static' heat resistant mats I found explain in the comments about how they are not really anti-static. And all the inexpensive, true EDS, anti-static mats are not heat resistant. (I'm sure there is one out there that has both, but it's likely out of my price range.)
Therefore, placing a $20 heat resistant mat on a $20 EDS anti-static mat would be the ideal choice? Is there something I'm not considering?
adamaero
  • 606
    Your standard *rubber* ESD mat is heat resistant, but yes they tend to be pricey. You can use wood as a cheap alternative (not plywood). Or maybe a thin piece of wood on top of a metal plate. – DKNguyen Oct 05 '20 at 13:34
  • Place a cat on top of an ESD mat, then pet the cat for a while. You'll build up a charge still. The word anti-static is unfortunate, because in case of ESD equipment it means "doesn't generate ESD in itself" and not "magically removes static charges occurring in other equipment". – Lundin Oct 05 '20 at 13:52
  • This ESD mat is within your $40 budget. Cut smaller than your normal sized bench mat for use in trays, but it's the real deal. https://www.mouser.com/ProductDetail/Desco/66126?qs=HePqyd4havIsNcPtRl6wAQ%3D%3D Do not forget the ground kit which is separate since it doesn't come with one (being meant for use in trays) – DKNguyen Oct 05 '20 at 13:53
  • @DKNguyen My price range is just less than hundreds of dollars. Since your first reply, I found this nice $45 all-in-one: https://www.digikey.com/en/products/detail/bertech/2059T-18X24GNKT/11680735 – adamaero Oct 05 '20 at 18:58
  • @adamaero you can't really call that one "heat resistant" – jsotola Oct 05 '20 at 19:47
  • @jsotola Given the listing is 190F, which is only 88C I would agree. On the other hand, the good Desco ESD mats don't have their temperature listed at all so I have nothing to compare with. Since brief contact with an iron is a fairly variable scenario. – DKNguyen Oct 05 '20 at 19:59
  • Their slightly thinner mat (1.52 mm vs 2.03 mm) says 140F to 210F. So I'm guessing 190 is an average: https://www.digikey.com/en/products/detail/bertech/2059S-18X24GNKT/11680809 The "high temperature" one may be 240ish degree F? Probably not since the surface is the same. – adamaero Oct 05 '20 at 21:53
No, it would not.
There's no conductive path through the silicone mat, so all having a proper one underneath it does is create a weak capacitor to ground, which doesn't help you.
Chris Stratton
  • 33,282
  • 43
  • 89
