I am working on a simple microcontroller based proportional controller to regulate the temperature of a heater cartridge using a feedback thermistor. I'm using the 'black pill' STM32F103C8T6 and have the controller working however I would like to send out time stamp and temperature readings over UART so that I can plot a graph of the temperature output vs time and use the Ziegler-Nichols method to obtain integral and derivative values (by obtaining the ultimate period of oscillation and ultimate gain).
I played around with DMA mode and ADC but had a lot of troubles so ended up using the simple polling method mentioned in the answer here:
The controller works in the main loop:
/* USER CODE BEGIN 2 */
usart_send_string("READY");
HAL_ADC_Start(&hadc1);
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
if (HAL_ADC_PollForConversion(&hadc1, 1000000) == HAL_OK){
waxThermistor = HAL_ADC_GetValue(&hadc1);
temperatureInDegrees = read_temp(waxThermistor); //Calculates the value in degrees using a look up table
if(heater==1){
HAL_TIM_PWM_Start(&htim3, TIM_CHANNEL_1); //PWM for heater element
heater = 0;
int currentTemperature = temperatureInDegrees;
int pi = PI(30,currentTemperature,50,0); //returns the controller value P + I
int actuate = limitActuation(pi,0,500); //Limits the actuation range between 0% and 50% duty cycle
htim3.Instance->CCR1 = actuate; //Sets the duty cycle
sendTemperature(currentTemperature); //transmits the temperature over UART
/* USER CODE END WHILE */
I would like to be able to send out a time value along with the temperature. I tried removing the polling and placing waxThermistor = HAL_ADC_GetValue(&hadc1);
in the interrupt routine for a 20ms timer (using OC mode) however I no longer get any PWM output as the ADC value is just returning 0 all the time. Could anyone recommend a better method for ADC sampling at a regular known interval rather than polling like this?
One possible solution I thought of would be to setup the ADC to trigger conversion on a timer and then read the sample in the conversion complete callback function. The time elapsed would then be the time between triggers + time taken for conversion to complete which can be calculated through the formulas given here. Would this be a viable solution?
For example if sampling every 20ms, the data sent out over UART would look like:
0ms;25c\n
20ms;27c\n
40ms;35c\n
