It has always been a big challenge for me to find the most general ideas behind great circuit solutions that can be illustrated by simple electrical concepts... and even by non-electrical analogies from our daily lives.
The differential (long-tailed) pair is such a legendary solution that deserves to be completely demystified. It is usually explained by electrical concepts (such as "current source")... which in themselves are not simple and clear enough.
Differential pair with dynamic load
The question arises, "Cannot we explain this strange topology with something even simpler, such as a resistor circuit?" If so, we can explain it to any electrician... and even to a 6-year-old (A. Einstein)...
Circuit fantasist
  • 13,593
Yes, we can… and it will help to understand this weird circuit solution at a lower level. Look at Fig. 1; it corresponds to the figure in the question body above. Only, it is implemented by an emitter current sink and, for simplicity, the current mirror is replaced by two collector resistors (the classic solution):
Differential pair - conceptual picture
Fig. 1. A conceptual picture of the emitter-coupled transistors ("current divider") - "a", and the dynamic load stage ("voltage divider") - "b".
Current divider
In the simple differential pair with emitter current source (sink), we can see the elementary electrical circuit of a current divider - two (variable) resistors with resistances rCE1 and rCE2 in parallel supplied by a constant current source. These "resistors" are a bit complicated - they are nonlinear (dynamic and voltage-stabilizing) and implemented with transistors... but this does not change the general idea.
Differential mode. We can demonstrate the circuit operation in differential mode with a humble potentiometer by connecting its halves in parallel - Fig. 1a. When we wiggle its wiper, the two partial resistances rCE1 and rCE2 crossfade (redistribute) and the common current is steered between them. In the real differential pair, the current is vigorously steered because of the dynamic resistances; if you want to emulate it, wiggle vigorously the wiper. The role of constant resistors Rc1 (Rc2) is to convert the partial currents to voltages since we need a voltage output... but we can demonstrate the principle with a current output by replacing the resistors with ammeters.
Common mode. To demonstrate it, we should change simultaneously (in the same direction and with the same rate) both resistances. We can implement this arrangement by two separate variable resistors with joined wipers.
Voltage divider
We can see the dual elementary electrical circuit of a voltage divider - two (variable) resistors with resistances rCE4 and rCE2 in series supplied by a constant voltage source, in the output stage of the more sophisticated differential pair with dynamic load - Fig. 1b. As above, these "resistors" are nonlinear (dynamic but current-stabilizing) and implemented with transistors... but this does not change the general idea.
The dynamic load stage is designed here to operate only in differential mode. As above, we can demonstrate its operation with a humble potentiometer by connecting its halves in series (the usual potentiometric connection) - Fig. 2. When we wiggle its wiper, the two partial resistances rCE4 and rCE2 crossfade (redistribute) and the common voltage is redistributed ("steered") between them. In the real differential pair, the voltage is vigorously "steered" because of the dynamic resistances; if you want to emulate it, wiggle vigorously the wiper. Here the output quantity is voltage; so there is no need for additional resistors.
Resistance vs current/voltage approach
Finally, I want to explain what is the point of working with resistances instead of currents and voltages when explaining, in an intuitive manner, electronic circuits with active elements (transistors).
Resistance is a more primary quantity than current and voltage; resistance is the cause and current and voltage are the consequence. When we say that a current source (transistor) changes its (collector) current, we only state the fact of the change but do not explain how this element does it. And the only way it can do that is by changing its resistance (the voltage is constant). So it is much more understandable to say "the current source increases its current by decreasing its resistance" instead only "the current source increases its current". Here I mean the common notion of a current source as not a true energy source but as an element keeping a constant current.
Therefore, whenever we want to explain a circuit to the lowest possible level of abstraction, it is a good idea to do it in terms of resistances. Of course, all this is valid if our goal is a true understanding of circuit phenomena on an intuitive level. If our goal is different (a homework according to the requirements of the teacher, a scientific article to build a reputation, a demonstration of great erudition, expression according to generally accepted canons and blind following of the dominant paradigm, etc.), this approach does not work but rather creates problems for us...
Circuit fantasist
  • 13,593
Examine the hyperbolic_tanh (which looks like an "S" on its side).
  • has the perfectly_balanced splitting (50% on each side) with Vdiff = 0
  • shows the limited "linear" region, for which we can craft polynomials that tell us the exact distortion, for which Barry Gilbert developed the translinear principle of compensation and high_range multiplication
  • shows the behavior at extreme input differences, where even hundreds of milliVolts V_differential will still show 0.1% or 0.01% effects, thus the diffpair is a SOFT LIMITER, which indicates the need to have several stages of gain
  • the limited region is useful in implementing LOG_RESPONSE amplifiers, even at RF signaling rates, over 50 or 100 dB variations in input level (you must be careful to avoid having an oscillator)
To explain what you have, those 4 transistors, is NOT the diffpair action alone.
The top 2 transistors are not, classically, included in diffpair operation.
I agree with LvW comment, in viewing the diffpair as a common_collector driving the input (emitter) of a common_base. Students of circuits do benefit from this interpretation.
With respect to Rene deCartes method of understanding, the 4 steps first revealed to me in the 4_volume 8_book Encyclopedia of Philosophy and nowhere else I have found,
  • the more and varied are the approaches to understanding (or modeling, or abstracting, of a concept), and the more moments spent by the human in mulling over (and over and over, from all possible aspects of the concept), the more likely the human will find new phenomena
  • KEY--- each time the human finds a new way to understand the concept, the human should sit quietly and RETHINK everything about the concept, to allow new neural pulse trains to be generated
  • KEY--- repeating the key--- sit and RETHINK everything, quietly
Given deCartes wrote in latin, I doubt this was an exact translation. But in the decades I've mulled over (pondered, looked at, viewed, run the numbers) various thinking challenges, in many situations of quietly mulling/thinking I do find delightful understanding (jonk has mentioned this discipline).
analogsystemsrf
  • 33,703
  • Interesting... but it exceeds my knowledge in the field. Maybe one day I will think about this... What do you think about my idea to explain the differential pair in terms of resistances? – Circuit fantasist Sep 27 '20 at 17:56
  • I agree with you - the top current mirror is not directly related to the topic; it is another interesting circuit story. I have introduced it here to show the "differential voltage divider" arrangement ("voltage distribution" principle) in the dynamic load output stage as a dual concept of the "differential current divider" arrangement ("current distribution" principle) in the emitter-coupled pair. The picture in the question body is exemplary; it is not specially drawn for this question. In the classic differential pair without current mirror, we can see only the "current divider" (steering). – Circuit fantasist Sep 28 '20 at 06:37
  • I think, the "classic" diff. pair is nothing else than a series combination of a common collector and a common base stage. This view enables us to immediately write down the known formulas for the diff. gain. – LvW Sep 28 '20 at 08:07
  • @LvW, That's right... especially in the case of a single-ended emitter-coupled amplifier... A powerful viewpoint... but here I show an intuitive explanation at lower level of abstraction... – Circuit fantasist Sep 28 '20 at 09:43
  • @LvW, As I have said above, your explanation ("the 'classic' diff. pair is nothing else than a series combination of a common collector and a common base stage") is valid only in the case of a single-ended emitter-coupled amplifier where the other base is grounded. In the differential mode, when the two input voltages change with the same rate but in an opposite direction, the differential pair should be considered as two common-emitter stages with virtually grounded emitters. In the common-mode, it consists of two "cooperating" common-collector stages (emitter followers) with joined outputs. – Circuit fantasist Sep 29 '20 at 12:46
  • I think that the restriction you have mentioned (...the other base is grounded) is not valid. When both input nodes (both base nodes) receive an input signal we can apply the superposition rule - and, thus, still consider the whole circuit as a common-collector-common-base combination...and this works also for common-mode inputs. Of course, the question arises, if such a view is helpful and can simplify the calculations... – LvW Sep 29 '20 at 13:36
  • @LvW, Perhaps I should clarify that I am interested not so much in the calculation but in the intuitive understanding of the mechanism of operation. From this perspective, the CE-CB-CC classification is too formal, restrictive and not so useful... I do not need it... But the superposition rule is an intuitive and really powerful tool... – Circuit fantasist Sep 29 '20 at 14:53
