I'm working with an ESP32 and a 4 relay module. The problem seems to be that the insulation of contacts in the relay is not enough.
wiring diagram
Relays close perfectly and my lights turn on, but when they open, a 20V or less voltage remains between the main contact and the normally open contact, enough to faintly turn on my lights. As you can see, my lamp is connected to the normally open contact of the relay. I've considered adding a resistor in series with the lamp to drop the voltage, no luck so far.
The datasheet corresponding to the part number:
https://pdf1.alldatasheet.com/datasheet-pdf/view/114955/ETC1/JQC-3F.html
In my case the manufacturer is BESTEP but the part number is the same, JQC-3F-05VDC-C.
Regarding the lamp, it's 5 parallel 50 watt COB LEDs. Couldn't find the datasheet.
photo of 50W COB LEDs
This faint light is greatly undesired. Any clues as to how to work around this?
SamGibson
  • 17,231
  • 58
If the relays are wired to bring out the NC contact you can wire the pole of the relay contact to the LED, the NO to the supply live and the NC to supply neutral. In this way, when the relay resets back to not powering the LED lamp, it will also short out the lamp (but not in a way that is dangerous).
It's possible that if there's several metres of wiring involved in the installation, there might be enough capacitive cross-connection between otherwise isolated conductors to drive enough reactive current to glow the LEDs.
There is no solution. The 240V input to the unit is connected to an internal bridge rectifier, shorting the 240V wont discharge the internal capacitor.
Moty
  • 238
  • Read the question, especially the 20 volt bit. – Andy aka Sep 26 '20 at 18:22
  • The 20V is 220V divided between the lamp and the voltmeter connected in series. There is no such thing as "Relay contact insulation doesn't seem to be enough". It could be that the voltmeter across the contact turns the light on a little. If the voltmeter removed the light will go dark in several seconds. – Moty Sep 26 '20 at 19:04
  • @Moty it is, if the relay is not a relay at all, but a solid-state "relay". And cheaply made; the mentioned "manufacturer" is a reseller of fell-off-a-truck-in-Shenzhen Alibaba junk. seen all over the usual digital flea market sites: Banggood, Amazon Marketplace etc. – Harper - Reinstate Monica Sep 27 '20 at 01:36
  • The board in the photo uses electro-mecanical relays, no SSR and no snubbers, only a dry contact. If a contact has low resistance it burns in a second from the power dissipated on it. – Moty Sep 27 '20 at 13:26
  • I don't connect the voltimeter in series with the lamp. This 20V were measure with the lamp disconnected and the relay in the off state – Mariano Franceschetti Sep 28 '20 at 11:48
