I supposed there is a sense coil inside the RCCB (RCD)of this tankless water heater. But why is there a fuse inside one of the load side to the circuit? Isn't the round circle the sense coil where the 2 load wire passes? Why isn't the fuse in one of them?
Part of
Jtl
The fuse is part of the RCCB control circuitry.
I suppose this is an North American system where RCCB and GFCI require selftest functionality. (UL 943)
The control circuit performing this test has a fuse to prevent fire in case of a failure.
This selftest is a regular intentional current across the sensing coil to make sure it detects.
It is wired on the load side so it will also be off in case of a fault.
Jeroen3
  • 21,976
  • 73
  • Looking at the colors, terminology and general construction, it seems more IEC than American, but it still looks pretty unusual. – Peter Green Jun 11 '21 at 23:50
