I have a wired heater controller attached on the wall. I lifted the controller and saw two power lines connected to it on the back. I was not sure how to measure the voltage. This Quora answer says:
IN ac mode, if it reads as zero then the output is either DC or Zero. If it is not zero then anyways the output has ac
But when I measured it with a cheap multimeter XL830L. When the knob at V~ 600 or 200, it read "20.0". Then I turned the knob to V- 200 or 20, it read 10.0 (but periodically dropped a little bit).
After measuring that, I completely detached the controller, and saw the back panel. There were + and - etched near where the cables were connected on the back. Then why did it read "20" when I the knob was at V~ 200.
