https://www.evwest.com/catalog/product_info.php?products_id=463
I am referring to the Tesla battery module listed in the above link.
It says a single cell has the following specs:
Nominal Voltage = 3.8V
Cell capacity = 3400 mAh
The cells are arranged in 74p6s config, therefore the voltage of the module is 3.8V * 6 = 22.8V The capacity should be 74 * 3400 mAh = 251,600 mAh or 251.6 Ah, 5.7 kWh
However, in the link, it says the module capacity is 232 Ah, 5.3 kWh
I am unable to figure out why it is mention 232 Ah, 5.3 kWh which doesn't work out in calculation.
Kindly advice
Update 1:
What is bothering me is the consistency of the inconsistency in calculation found in many websites. So I figure there must be something I am missing.
For example
http://store.evtv.me/proddetail.php?prod=TeslaBattModule
https://stealthev.com/product/tesla-module/
Update 2:
Thanks for the valuable inputs everybody. It makes sense to me to think that the manufacturers will limit the module / pack capacity using their Battery Management Systems to prolong lifetime of the cells.
I will just leave it at that. Because I am only working on developing some simulation models I can live with my calculation and set a buffer if needed.
